Does stopping a program reset it?
I have two programs to turn on and off my theater's ISY controlled devices. If I run the Then section of theater off, it runs for about 20 minutes. If I decide to turn back on the theater during that 20 minutes, I want to stop the off program from running so the on program can run. If I add a line to Stop the off program, will the off program run in entirety the next time I activate it?
Here are the programs I wrote:
Theater ON
IR 'IR_020' is Pressed
Stop program 'Theater OFF'
Set 'Theater / Receptacle / Theater NE' On
Wait 1 second
Set 'Theater / Receptacle / Theater NW' On
Wait 1 second
Set 'Theater / Receptacle / Theater SW' On
Wait 5 seconds
Set 'Theater / Receptacle / Theater SE' On
Wait 1 minute
Set 'Indoor / Thermostats / Theater / HVAC Theater' Mode Cool
Wait 5 seconds
Set 'Indoor / Thermostats / Theater / HVAC Theater' Fan Auto
Wait 5 seconds
Set 'Indoor / Thermostats / Theater / HVAC Theater' 80° (Cool Setpoint)
Theater OFF
IR 'IR_019' is Pressed
Set 'Indoor / Thermostats / Theater / HVAC Theater' 76° (Cool Setpoint)
Wait 5 minutes
Set 'Theater / Receptacle / Theater SW' Off
Wait 5 seconds
Set 'Theater / Receptacle / Theater SE' Off
Wait 5 seconds
Set 'Theater / Receptacle / Theater NW' Off
Wait 5 seconds
Set 'Theater / Receptacle / Theater NE' Off
Wait 15 minutes
Wait 5 seconds
Set 'Indoor / Thermostats / Theater / HVAC Theater' Mode Off
Looking at the above programs, if I press ir_19 and begin the Off program and then 5 minutes later press ir_20 to run the On program it will stop the Off program. The next time I press ir_19 will it begin at the beginning of the Then statement or will it pick up where it left off?
Yes. It will not start in the middle of the program. Each time you run a program, it will start at the beginning.
