ISY not showing Insteon events in Event Viewer
Hey All,
I'm running an isy994i pro with version 5.3.4 of the ui and firmware. I am having issues that I don't want to get into otherwise I'm afraid this thread will get off the rails. The basic symptom that I see is that physical presses of Insteon devices do not fire events in the Admin Console Event Viewer. ie. If I go to a switch and press it on or off I do not see an event in the event viewer. This is true for dimmers switches, key pads and outlets, all Insteon devices. I do see events in the event viewer if I trigger the event from the admin console or if the events are triggered from programs running on timers or node servers (Open Weather for example). So events do show up in certain cases, just not from physical presses of devices. I idon't have anything other than Insteon so can't say if it's a problem with other devices.
Questions
1) Can anyone confirm that Insteon devices should show events in the event viewer when physically pressed?
2) Can anyone confirm that this works in version 5.3.4?
3) Does it matter if the events are shown in the Event Viewer? As in, is this a problem or not?
Thank you in advance!
