iAquaLink aux randomly turning on
I've had a very strange problem for a while now, randomly one of my aux devices will turn on.  This device is not in any program, except for the one which monitors if it is on and notifies me.  Here's the excerpt from the log where it turned on today, logging was only in info mode.
2024-03-22 17:15:16,289 Thread-174275 udi_interface      INFO     iaqualinkns:longPoll: Sending Heartbeat command to iAquaLink service node...
2024-03-22 17:15:16,290 Thread-160873 udi_interface.interface DEBUG    interface:_send: PUBLISHING {'command': [{'address': 'service', 'cmd': 'AWAKE'}]}
2024-03-22 17:15:16,372 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message command
2024-03-22 17:15:16,373 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING command
2024-03-22 17:15:16,373 Command    udi_interface.interface DEBUG    interface:_handleInput: PROCESS command message {'address': 'service', 'success': True} from Polyglot
2024-03-22 17:15:30,151 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message shortPoll
2024-03-22 17:15:30,152 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING shortPoll
2024-03-22 17:15:30,152 Command    udi_interface.interface DEBUG    interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2024-03-22 17:15:30,152 Thread-174277 udi_interface      DEBUG    iaqualinkns:shortPoll: In shortPoll()...
2024-03-22 17:15:41,318 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message command
2024-03-22 17:15:41,319 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING command
2024-03-22 17:15:41,319 Command    udi_interface.interface DEBUG    interface:_handleInput: PROCESS command message {'address': '189308_aux_1', 'cmd': 'DON', 'query': {}} from Polyglot
2024-03-22 17:15:41,319 Command    udi_interface      INFO     nodes:cmd_don: Turn on aux_1 in DON command handler: {'address': '189308_aux_1', 'cmd': 'DON', 'query': {}}
and the PG3 log shows it happening:
3/22/2024, 17:15:41 [pg3] info: [00:21:b9:02:5d:7d(20)] IoX HTTP Inbound: Received DON for node: 189308_aux_1
3/22/2024, 17:15:43 [pg3] info: Received commands on topic udi/pg3/ns/status/00:21:b9:02:5d:7d_20: set
3/22/2024, 17:15:43 [pg3] info: IoX Request: [Try: 1] [00:21:b9:02:5d:7d] :: - http://localhost:8080/rest/ns/20/nodes/n020_189308_aux_1/report/status/ST/1/25
3/22/2024, 17:15:43 [pg3] info: IoX Response: [Try: 1] [00:21:b9:02:5d:7d] :: [200] :: 1.903103ms - http://localhost:8080/rest/ns/20/nodes/n020_189308_aux_1/report/status/ST/1/25
So obviously something is sending the DON but I can't figure out where it is coming from.
The ISY Log only shows:
PoolSpa / Pool and Small Spa / Slide	Status	On	Fri 2024/03/22 05:15:43 PM	System	Unknown
I now have the event viewer open to see if I can catch it triggering.
If anyone has an idea how this could be happening, or more ways to debug please let me know.
- Jim
It does appear the DON command for aux_1 is coming from IoX.
Yes appears so, but I just can't figure out how. I had a random issue like this after upgrading to eisy, so deleted and readded the device and the problem went away. I'm tempted to do it with this as well if event log can't catch it.
Sent from my Pixel 8 Pro using Tapatalk
Could it be coming from the web interface for iAqualink... an old program that is running?
I don't think so because based on the plugin log it's being sent a DON which can only come from isy. If it was turned on by something else it would just be a ST change.
I deleted the node, restarted the plugin and isy. So far it hasn't happened again but will take a few days before I know for sure.
Not sure I understand the current context. No node for aux_1 in IoX, yet aux_1 is still turning on randomly? Are there any corresponding log entries for aux_1 and DON commands, like in the first log snippet you posted? Have you tried shutting down the plugin for a couple of days to see if the random aux_1 behavior stops?
Just FYI, I did a quick check to verify that the cmd_DON method that generates the INFO log entry in the first post is not called by any other part of the code, i.e., only called as a result of DON commands received from PG3 for the node.
Edited by Goose66
Yes, but what I was asking you was if you agreed that based on the log I posted in the OP that it looked like IoX was turning on the device?
No
That was my next test, but I thought just deleting the node would suffice.  But I like having it running because I have IoX send me a notification whenever that slide (or any other node we seldom use) is turned on because the pool guys sometimes forget and leave them on.
Thanks, that was my next question.
