Cannot launch polisy Admin Console: Invalid URL
My Polisy has been accessible from my Admin Consule for the past 10 months with no problems.  All of a sudden it went missing from the IoX finder.  I added back its URL that I copied from my ISY portal, but now I get "Invalid URL" when I try to launch the Admin Console from that URL in IoX finder.  I know my Polisy is working because the programs are running correctly, and I can also operate it just fine from UD Mobile on my iPhone.  I can see it sitting at the correct IP address on my network using other locator apps.
Solved by Javi
It is likely an invalid URL, be sure is starts with "https" and ends with "/desc".  Local connection can also be used with the http:<ipAddress>:8080/desc where IP Address is replaced with the units local IP Address (i.e. something like 192.168.1.65).
Thanks for the alternate URL format.  It worked, but only after a rebot :-)
The URL fromn the ISY Portal was correct, but it still doesn't woprk.  I've deleted it, as the alternate URL is working fine.
