djmatth2 Posted May 12, 2024 Posted May 12, 2024 Running 5.8.3 and rebooted eisy. Have a dead zwave device - can't exclude. Took remove option under Zwave menu. Processes for 20-30secs (shows 48% complete) and then throws he following error: [LIB_DRIVERS-UYZ_GEN_ERR_9_BODY]. Dialog box has title {LIB_DRIVERS-UYZ_GEN_ERR_9_TITLE] Device doesn't remove following the error. Any suggestions please? Thanks
Solution dbuss Posted May 12, 2024 Solution Posted May 12, 2024 On 5/12/2024 at 3:31 PM, djmatth2 said: Running 5.8.3 and rebooted eisy. Have a dead zwave device - can't exclude. Took remove option under Zwave menu. Processes for 20-30secs (shows 48% complete) and then throws he following error: [LIB_DRIVERS-UYZ_GEN_ERR_9_BODY]. Dialog box has title {LIB_DRIVERS-UYZ_GEN_ERR_9_TITLE] Device doesn't remove following the error. Any suggestions please? ThanksRight click on the device and select delete. This will delete the device from your eisy. The device would need to be factory reset before trying to include in a system.Sent from my SM-G998U using Tapatalk 1
djmatth2 Posted May 12, 2024 Author Posted May 12, 2024 Thanks that solved it. I had tried to delete before doing the Zwave remove. It wouldn't let me do that, but I never tried the delete again after the error message from the remove - Duh........
