I was able to updates my nodes (only once) and now it is failing every time. The app (upon restart on PG3) will load 15 node updatings but also error out with an AIP key error. See screenshot below.
I am trying to pull data from 3 weather stations.
Also, attached debug file as well.
AmbientWeather_7-5-2024_93624_AM.zip
Solved by bpwwer
From the log, the queries the plug-in is making to ambient.net appear to have an invalid API key.  That's the message the Ambient servers are returning when that query is made.
The plug-in can't force Ambient to accept an invalid api key.  Double check that your key is correct and valid.
I have checked and re-checked several times. I cut and pasted exactly as it was presented to me.
Here is a screenshot from the PG3 node:
I have also:
  1. Restarted EISY
  2. Cleared cache
  3. Un-installed and reinstalled AW nodeserver from PG3
  4. Installed in different node slots
What to do?!
Ecobee and RING nodeservers work great
