Anyone having portal connectivity issues?
Starting last night my alexa integration stopped working. (alexa would make the tone like the command worked by the skill command to turn on a light didn't work. This morning I started looking deeper. From UD mobile everything works fine controlling my ISY as long as I am local, if I disable wifi and try to test remote connection from the app it times out. If I login to the isy portal it tells me my ISY is online with firmware 5.3.4. If I goto ISY information in the portal all it shows me is the UUID, all the other fields are blank. I also see nothing under logs, If I click on events or errors it just sits there saying retrieving.
I also keep getting an HTTP error 408 from the Portal website.
Is there a portal issue going on?
I am experiencing the same issue with Google Home. Just recently as well.
In addition to HTTP error 408, I'm also receiving a "Devices are not available" message as well. I can control things locally just fine. Seems to be related to the portal access.
Edited by stimpy2k
I also started experiencing issues 7/17 early in the morning. Can't seem to figure out if it's a Portal issue or a DNS issue.
