Can't delete Zigbee device
Awhile back as a test I temporarily added a Sengled Zigbee bulb to eISY and later decided to add it to Home Assistant instead, it is now controlled by HA. As a result of adding it to eISY, I now have two devices with a red slashed circle on eISY that I cannot delete. I've tried:
1. Right click device/Remove from Zigbee network (no error, but does not delete)
2. Right click device/Delete ("Request failed", does not delete)
3. Factory reset Zigbee dongle and repeat steps 1 and 2. Same result as above.
Any suggestions on how to remove these phantom Zigbee devices?
EDIT: Just upgraded to 5.8.4 firmware and the devices are gone.
Edited by landolfi
Problem solved
