Unable to connect to Bridge after install of 3.2.14
I installed the new version and it doesn't find my bridge. Log shows the following errors:
024-07-19 16:28:05.442 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2024-07-19 16:28:05.442 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2024-07-19 16:28:05.443 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db95945a0_2/main.py", line 9, in <module>
2024-07-19 16:28:05.445 MainThread udi_interface ERROR udi_interface:write: from bondns import BondNS
2024-07-19 16:28:05.446 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db95945a0_2/bondns/__init__.py", line 5, in <module>
2024-07-19 16:28:05.448 MainThread udi_interface ERROR udi_interface:write: from .bondns import BondNS
2024-07-19 16:28:05.449 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db95945a0_2/bondns/bondns.py", line 14, in <module>
2024-07-19 16:28:05.451 MainThread udi_interface ERROR udi_interface:write: from .nodes import Bridge, Generic, CeilingFan, Light, NoDimLight, Shade, Fireplace, KeypadButton
2024-07-19 16:28:05.452 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db95945a0_2/bondns/nodes.py", line 13, in <module>
2024-07-19 16:28:05.454 MainThread udi_interface ERROR udi_interface:write: from .bondapi import *
2024-07-19 16:28:05.455 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db95945a0_2/bondns/bondapi.py", line 177, in <module>
2024-07-19 16:28:05.458 MainThread udi_interface ERROR udi_interface:write: class bondBridgeConnection(object):
2024-07-19 16:28:05.459 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db95945a0_2/bondns/bondapi.py", line 180, in bondBridgeConnection
2024-07-19 16:28:05.461 MainThread udi_interface ERROR udi_interface:write: def __init__(self, hostName: str, token: str, stateCallback: Callable | None = None, eventCallback: Callable | None = None, logger: logging.Logger = _LOGGER):
2024-07-19 16:28:05.462 MainThread udi_interface ERROR udi_interface:write: TypeError
2024-07-19 16:28:05.463 MainThread udi_interface ERROR udi_interface:write: :
2024-07-19 16:28:05.464 MainThread udi_interface ERROR udi_interface:write: unsupported operand type(s) for |: '_CallableType' and 'NoneType'
I tried entering the IP and token manually and also reinstalled the plugin but neither of these steps worked.
Currently running PG3X 3.2.22 and IoX 5.8.3 on Polisy.
Solved by oneklakes
