Error running fl.ops script and setting up partition system for new NVME disk
My goal is to boost performance and maybe run VMs.
I followed instructions on this blog post to set up a simple NVME disk.
Then I found this blog post to https://developer.isy.io/blog/eisy-way and attempted to run the fl.ops script. I got this error:
[admin@eisy ~]$ sudo fl.ops setup.nvme.boot
executing from /usr/local/etc/udx.d/static
gpart: No such geom: nvd0.
 nvme0: WD_BLACK SN850X 1000GB
    nvme0ns1 (953869MB)
Wed Jul 24 11:16:55 PDT 2024|/usr/local/etc/udx.d/static/fl.ops: adding GPT partition to nvd0 ...
gpart: geom 'nvd0': Operation not permitted
Wed Jul 24 11:16:55 PDT 2024|/usr/local/etc/udx.d/static/fl.ops: error: failed creating gpt partition ...
It's looking for nvd0 which doesn't appear to exist. I'm running UDX version 3.5.6.4.
I know should have followed the multiple partition instructions but am a noob to Linux and get this error when I try to follow the instructions to set up the partition system:
sudo gpart create -s gpt nvd0
It doesn't seem to like nvd0 for some reason. It seems to be the same error that @Michel Kohanim mentioned could be due to a size issue in this thread.
So for clarity, I'd like to:
1. Set up multiple partitions
2. Use one partition to mirror the OS to boost performance
3. Use the other partitions to run other services like CumulusMX
Any guidance?
Edited by cosyn
added link to another thread
  • 3 months later...
I just got my eisy to upgrade my old 994i and I am running into this same issue after installing a 1t Samsung 990 pro.
