Can't get into PG3
I purchased an EISY and have spent hours researching how to get into PG3 to purchase node servers, without success.  I can access it via the EISY main menu, but the login page isn't working.  I A few things I've tried:
  • Cleared Cache.
  • Per the Wiki, use the default admin/admin (which is also what the EISY was currently set to).
  • Per the Wiki, I changed the default user/password on EISY admin console, and then it says that login will work for PG3.
  • Used the ISY Portal login.
  • Tried combinations of username from Portal, email address from portal, admin console username, default/default, and combinations of all the above passwords and usernames but nothing seems to work.
Any suggestions?  I just want to see what all is available for purchase to see what EISY is capable of doing.  Thx!
Solved by drprm1
Well if all you want to see is what is available go here  https://polyglot.universal-devices.com/
But I’m sure you’ll want to purchase some
Thank you, drprm1!
I'm actually wondering if it's NOT my credentials, but maybe the entire service is down?  This is what I get when I login:
Have you rebooted EISY. I suggest power cycling it….
Or
Rebooting seems to have resolved the issue!  Thank you so much for the assist.
