dead on arrival
had a few issues earlier.. regardless, this will not install or update.
it shows and install.ns error 500....
Solved by EWhite
When you say “it” shows, do you mean the logs on pg3?
it shows in a little red box on the the pg3x webpage when i try to install it.
i was running 3.0.6 just fine...but HAD to do an update that forced a reinstall of the newest...
I have not seen that error before. Searched around on the forum here & found it on the notifications plugin. Looks like a reboot solved it.
Thanks @EWhite for keeping us up to date on the journey.  I am sure this was not on your agenda for tonight to work on.  Sorry about that.
ok.. @Michel Kohanim got me fixed up.. seems i had a botched update that didnt load all the packages i was supposed to have...
after much time from Michel, he got it all fixed up and plugin installed properly and is running as designed!
Class A number 1 service hands down!
Thanks to all involved!
Good deal @EWhite , appreciate the update!
you mentioned 'a few issues earlier', would you mind marking this as solved and add those issues to the stream for v3.1.11?
