I know the name of a plug-in Insteon module; how do I figure out what programs it's in?
I went to install something neat a lamp that's in our upstairs hallway.  The lamp was plugged into the outlet, but in the outlet also was an Insteon plug-in lamp module (lamp not plugged into the module).  Using the address written on the lamp module, I found that the module is called "Lamp upstairs hallway".
I assume I had it programmed at one time, and then someone unplugged the lamp from the module.
Is there a way to use the address and/or name of this module to determine which program(s) it's in?
Solved by paulbates
Thanks for the fast response.  Hmm...it's in at least 3 programs: a going to bed one; a "normal" daily routine"; and a guest routine (to lowly light the hallway while guests are upstairs).  I'm plugging it in again.
