A couple of minor issues with 1.2.3 update today
1. This has been an issue for a while.  After any update my short poll goes back to 60.  Why cant it save the 180 I sent it for due to all my devices?
2.  This one is new.  I can post a video or send you one PM if you cant reproduce but after I update from 1.2.2 to 1.2.3 it shows 1.2.3 for about 5 seconds and then goes back to 1.2.3   The UPDATE button stays there so it thinks it needs an update but no update blue banner.  I can also send a log package if you want
17 minutes ago, Jimbo.Automates said:
1. Did you turn off auto set shortpoll? That was added in previous release which should set the proper minimum poll based on how many devices you have.
2. I'll take a look
Sent from my Pixel 8 Pro using Tapatalk
1. It was on but the short poll number changed which I assume is what it set to but I had already changed it.  Fixed now and ok.
2. Let me know what you find and I will reinstall once you say to.
I just tried agian and it still stayed on 1.2.2 (you may not have looked at that yet)
BUT
I left Admin Console open.  On update the TRUE switches to FALSE and then the short poll goes to 60.
Is it supposed to hold when doing update?
I said I would take a look, I never said it was fixed.  I'll try to look tonight after work if I have time.
On update, or on all restarts?
Just checked.  RESTART holds the setting.   UPDATE loses it.
The 1.2.3 version issue is fixed.  But there are 2 issues with PG3 that I've notified @bmercier about.
1. On upgrade install PG3 is resetting shortpoll back to default.
2. If you change Controller -> "Auto Set Short Poll" = True, then on restart it will put it back to False
I created programs to set mine back to desired value to get around this issue until we can resolve.
Confirmed fix and issues here.  THANKS.  will watch for a pg3x update
22 hours ago, Jimbo.Automates said:
Version 1.2.4 should fix this until PG3X is fixed:
- 1.2.4: 08/11/2024
  - Restore "Auto Short Poll" and "Short Poll" values as saved in PG3 DB
well it works but I keep getting the message that its set at 60 and as you can see in screenshot it is correct!!!!
http://d2z8ydsemzif1x.cloudfront.net/monthly_2024_08/Screenshot2024-08-12at1_38_21PM.thumb.PNG.fc512ed165c6e29e6a03a44719615034.PNG
Did you change it in the PG3 UI? If so, the Plugin has no idea that you changed it until you restart. I asked @bmercier if this could be added so hopefully it can be.
Change it in the AC of UDM.
Set to auto in admin console    I did not restart but did update which did not hold so I set it again (expected not to hold until latest update)   Then kept getting messages so I did a restart of nodeserver   No message since which is good
Should be fixed in 1.2.6
yes seems to be fixed.  thanks
