MS II 2844-222 with EISY - Battery Sense says FALSE with battery installed
Try as I might, my MS II Says 'FALSE' to battery powered when in fact it is being supplied by a battery and will not indicate battery %.
I have tried:
- Resetting to factory default
- Removing battery and plugging in to USB, then reset, the go back to battery and reset
- Changing battery node from 1 to 0, reset and back to 1 and resetting
- One time it did show up randomly, but did not track the battery level. Then it reset to FALSE for battery power again.
I am using UD EISY to control the sensor. See settings on attachments.  Note Screenshot B - Battery nodes does = 1.
Thanks in advance for any help.
John
  • 1 month later...
I am experiencing the same issue.
I upgraded from ISY994 to EISY a few months ago.  Before upgrading, the 3 Insteon Motion Sensor II 2844s I am using were reporting Battery Powered correctly along with a usable relative (but not accurate) Battery Level. After upgrading, Battery Powered usually reports "False", and Battery Level is rarely updated.
It seems like the much faster EISY isn't waiting long enough for the MS II to complete its transmission of the data.
Any advice is welcomed.
