glsmith777 Posted August 17 Posted August 17 On one of my Insteon 2477S devices, the address seems to have been damaged when I removed it from service a while back. I would like to reinstall it, but I can only read a portion of the address It looks like xx.x0.72. I recall when I was using the Insteon hub, I could push the set button on the device and the hub would discover it without having to enter an address Does eisy have a similar feature - or do I have to trash my Dual Band SwitchLinc On/Off Switch device? I tried to "Auto Discover" by selecting the device type 02.2a from the pulldown list - but it returns instantly - assuming it requires an address. Thanks in advance And BTW - I agree with other post about adding Insteon devices - it would wonderful if the device list could be sorted by device code (i2477S) in addition to the existing device types (02.2a) sort Greg Quote
paulbates Posted August 17 Posted August 17 The ISY does have this feature. Under the iox linking menu, press "Start Linking" at the top. Then press the set button until the switch double-beeps. Then press the button iox to complete the process 2 Quote
Techman Posted August 17 Posted August 17 @glsmith777 After you add the device create a topology report, TOOLS | GENERATE TOPOLOGY, this will give you a list of all your devices and their address along with other helpful data. 1 Quote
