Device Detection issue with Casablanca Fans
I have 4 ceiling fans that all work perfectly with Bond Bride by the app or by voice.
I installed Bond for Polyglot 3x and setup custom configuration..
When I run discover the Bond plugin finds my bridge and only my bedroom fan/light.
My 3 Casablanca fans are not discovered. I noticed these fans have limited information in the bond app compared to the fan that works.
Please Advise!
Solved by atmarosi
Under advanced it’ll show “Devices Associated” - is that actually showing all the devices?  What kind of Bond hub is it?
That should match the number of fans you have…. Seems like you need to retry pairing the fan units to the bond first
I removed each device and added it back and the Bond bridge now sees all 4 fans as attached.
Polyglot is also working great.. thank you for your help
