Bladerunner Posted September 15, 2024 Posted September 15, 2024 (edited) I removed some devices from Eisy. I then went over to HA and reloaded the Universal Devices integration, expecting the devices to be gone. They were not. I thought that reloading the integration would cause the Eisy to be queried and only the existing devices/entities would be there. Do I have to remove those devices manually? Edited September 15, 2024 by Bladerunner
shbatm Posted September 15, 2024 Posted September 15, 2024 Try a full restart of Home Assistant. The integration should not reload the entities, but Home Assistant has some retention of these (e.g. in case of an integration failing to load or only partially loading, it still retains the old state/name details).
Bladerunner Posted September 15, 2024 Author Posted September 15, 2024 Interesting. I did a full HA reboot and I still see those devices.
Bladerunner Posted September 16, 2024 Author Posted September 16, 2024 Well it was Z-Wave and I didn't remove them via the Z-Wave menu. I went back and removed then via that menu options allowing Eisy to remove them. Tried a reboot of Ha and it still shows them. Will keep trying.....
Bladerunner Posted September 16, 2024 Author Posted September 16, 2024 After Z-Wave removing the devices in Eisy, I then went over to HA. I attempted to delete the devices but it said they couldn't be found. So, it seems that they were gone but that the devices were not removed from the integration. So all is well it seems. I guess.....
