Ecobee reverting back to Home settings due to motion
I am trying to use Geofence in UD Mobile with my EISY to set my Ecobee3 to Climate Type "Away" (64 deg for example) when I'm gone.
When I return, I would like the Climate Type to change to "Home" (70 deg for example).  This all works.
The issue is if I change the thermostat manually at the Ecobee to 72 deg and the thermostat sees motion in front of it, it restores back to the "Home" set temperature of 70 deg.  I have tried hold indefinitely, hold next, and a host of other things.  I've even tried to put electrical tape over what I thought was the motion sensor on the Ecobee, but that did not work.
Any assistance would be appreciated.
