Elk PG3 and Home Assistant
IPG3  am running the Elk NS and Home Assistant.  Do I need to have the Home Assistant integration installed to see my Elk devices.  I don't and don't.
I DO see my Elk NS and my two areas, House and Shop. But there are no devices shown in either area.
Just wondering if is intended that I need to install the Elk integration in HA in order to see my devices.
If you install HA elk integration, it will work directly with ELK. No need for pg3 plug in. Most likely HA isy integration does not have full support for such a complicated device but you can try to ask the author in HA forum.
