showing disconnected
I have two Web8 controllers. I have installed 2 plug-ins with different IP addresses etc.
At first they both worked. Had a lock up on my eisy. Upon restart I could not get web8 RIGHT, to work at all.
I am remote, so I went directly into the web8 to ensure it was connected. It is and I could access all the screens w/o problem.
Went back into PGX, erased some of the config values, put them back in, and it still shows as Disconnected, but it did retrieve my temperatures. image.thumb.jpeg.8ce31ee9d4af5fcde046ee42d138d899.jpeg
I have stopped and started it a few times, no changes. attached is the log fyi.
The other plug in shows a 1 in the ST driver vs zero in this one.
WebControl8_10-28-2024_13416_PM.zip
Solved by dbwarner5
upon further investigation, it doesn't seem to be going to the right port. From the log:
wc:fetch_data: Fetching data from URL: http://192.168.68.44:80/getall.cgi 2024-10-28 13:30:27.713 Thread-76 (poll) udi_interface
ERROR    wc:fetch_data: Error fetching data: HTTPConnectionPool(host='192.168.68.44', port=80
Have tried to delete the 84, put in 80, saved it, stopped and restarted PI.. then did it again, but deleted the 80 and put in the 84, saved, stopped restarted.
Still not working.
Ok.. I tried once more by changing it to 90, then back to 84 and VOILA!  it worked..
Strange.
Hi @dbwarner5, Very strange. It looks like it took the port for a short time but then reverted back to 80.
It is strange that the other instance of webcontrol is working fine.
I remember you mentioned that you had problems with one of the plugins accepting the new port at first. Was it this plugin by chance?
I wonder if something may have happened that was quirky during install.  I would delete the plugin and reinstall. Once it is reinstalled try changing the ip, port, username and password (unless they are default user/pass) then pressing save to see if there might be any difference.
-Tim
