Wrong Port again
Had to restart my EISY. Both of my WebControl Plug ins are searching fro port 80, even though in the config, I have 82 and 84.
See screen shots below.
thanks.
Solved by dbwarner5
After playing with it for 20 minutes, changing various settings, I was finally able to get them both to stick.
Cant say what I did but essentially changing the port to other numbers, restarting, changing it back, restarting, sometimes just chaining the port and saving, sometimes hitting the top save button, sometimes the bottom.
So bottomline, I cant tell you what worked, but it too 20 minutes of trying to get them both to stick.
thanks.
I just switched one of my instances on each eISY over to port 84. I set the first one, then the other, both instances took to the new port right away. I will let them run and monitor them for glitches or fails and report back.
Very strange.
-Tim
For some strange reason, this time when stopping and restarting, the port did not persist thru restart.
Looking into it.
My apologies.
13 hours ago, TJF1960 said:
@dbwarner5 version 1.0.11 is available. Please give it a try.
Custom Port now persists reboots, starts and restarts.
Whew.. glad I wasn't losing my mind!!
THANKS!!
