I have a 2443-222 on/off module controlling my flood lights. My question is can I detect when the yellow sense 1 wire triggers the unit so that I can use that in a program? I want to know when just the yellow sense 1 wire turns on the lights.
Posted (edited)
Yes. I have a lamp post photo cell connected to one to turn my premise lights on at dusk.. Based on light level. Same could be done with a motion sensor.
Edited by paulbates
When 120VAC is applied to the Yellow wire. With respect to the Neutral. The full manual would give you a good idea on how it is connected and works.
It it is a high impedance input. We have seen reports of some photocell and motion sensors. Using a triac and not a relay. Having enough leakage to falsely trigger the module.
Sorry I took so long to get back with you, the yellow wire is connected to a small relay. I have a PE cell controlling a small relay and then the relay controlling the 2443-222 yellow wire. I have done this because of PE leakage even when they have relay outputs. What I was wanting to do is control the flood lite time on with my eisy and not the PE cell, but at the same time I want to control the flood light with just my eisy. I am doing this now but without the yellow wire time on part, it is now being controlled by the PE cell. I can turn Food light on and off at will and the PE cell takes care of any motion control.
Thank you
Richard
I don't have a 2443 to look at but could you eliminate the PE cell and use a Sunset/sunrise  program to trigger the switch.  If you need motion you could add an insteon motion sensor.
I've used the Insteon motion sensors outdoor for many years without problems. I have them mounted under eves so they don't get directly exposed to rain.
If you have Zwave then ther are waterproof outdor Zwave motion sensors available from Zooz
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
      37.5k
      375k
