November 4, 20241 yr I have a random on. I have 3 switches that will come on at sunset and turn off at a given time. There are no programs running to execute at that time. I check the summary, no programs run at the time these lights come on. One of the switches I deleted from isy, and it doesn't turn on randomly anymore. If I re add it, it will turn on randomly again. How do I figure out what is triggering these 2 switches to turn on?
November 4, 20241 yr Take a look at this article INSTEON Random All On Events - Universal Devices, Inc. Wiki
November 5, 20241 yr Author here is a topology of my setup. Hopefully someone can figure this out. otherwise im gonna have to do a full reset ISY Topology.v5.3.4__Tue 2024.11.05 07.27.30 AM.html ISY-Events-Log.v5.3.4__Tue 2024.11.05 07.24.35 AM.txt
November 5, 20241 yr I see you experimented with deleting switch then adding it back…Did you happen to hard reset it a few times to get rid of any links before adding it back. Go to programs and using find/replace make sure the switch isn’t in any programs.
November 5, 20241 yr Author 11 minutes ago, drprm1 said: I see you experimented with deleting switch then adding it back…Did you happen to hard reset it a few times to get rid of any links before adding it back. Go to programs and using find/replace make sure the switch isn’t in any programs. No didnt try that. Thought that if i deleted it, it would delet all links. Only switches that are physicaly linked is to the remote link. And now that i think about it those are the ones turning on randomly. Edited November 5, 20241 yr by diggler
