Google sign-in
Portal now supports an easier method to sign-in using a Google account.
If your portal email address is a gmail account, you can use Google sign-in for a faster login.
If a portal account does not exist for the google email address, a new account will automatically be created.
If you currently use a non-gmail address to login to portal and would like to use a google email instead, then proceed this way:
  1. Login to my.isy.io and click on users
  2. Add a user profile with the same email address as your google account
  3. That's it.
You can now use Google Sign-in, to login to your portal account. There's no need to validate your email address, you can ignore the verification email.
Optionnally, you can remove your previous use profile. If so, and if you are using Google Home or Alexa, you will have to relink the skill with with the new user profile. Your spoken configuration will be preserved, all you need is to relink.
