Remaining Battery
@Panda88 I just updated to this version of the nodeserver and found that the status condition on Remaining Battery only allows "kWh" or "other" in program conditions whereas the previous version allowed %.  There also appears to be a bug when "other" is selected as it only allows "98" or "no data" for the pull down.  Any chance the remaining battery can be updated to also allow "%"?  The remaining battery value when selected to either Index or kWh also does not report anything in program actions (it is reported on the status screen though).
Edited by PGHBubba
Tagged Author & Added additional bugs found.
Solved by Panda88
Thanks.  I think I will revert back to the old version.  I did several experiments and cannot get the powerwall battery value in any program, even set as kWh.  It shows up in the nodeserver (GV0) as the correct value as well as the admin console in the main screen and it matches my Tesla app but for whatever reason it is not able to be used in a program.
Different slot.  Tried various things: Stopping the old version.  Then deleting the old version in case they were stepping on each other.  I also lowered my battery level from 100% (we are in active storm watch mode all day due to weather) to see if it needed to change to be reported.  No luck.   I created a temporary variable to write the battery value to (as kWh) and it would never change (variable stays at 0.0000).
I see the problem
Let me take a look and see if I can figure out what is happening - it is likely in the node definition
