Symptoms of failing PLM
I keep seeing red blinks on some switches when locally pressed.  I've had the issue with device being randomly turned off and now I've had 2 times where all the devices came on (like if you do on with the my lighting scene).
Then last night no device presses would work on switches but I could control them from ISY.  Looked and all the links in the PLM were gone.  I don't think I accidentally held in the button when plugging in. Restored it fine and then all lights came on at 4am.
Sound like a failing PLM?
Solved by paulbates
Another symptom is a dim or out LED on the side.
Can be rebuilt built. These days most go the new latest version PLM.
