Dimmer Keypad, 8-Button 2334-222 as on/off
5 minutes ago, Techman said:
No. The dimmer uses a triac and the on/off uses a relay.
Its too bad the stopped making the on/off 8 button keypad....cant seem to find an old one on ebay either.
5 minutes ago, paulbates said:
The 6 and 8 key versions can be switched between 6 and 8 with some setup key presses. If you have the screw on 8 keys part or have an old one lying around you could get there
Im not following.  Are you discussing a model other than the 2334-222?
You can change the 6 key facia on the relay keypad to an 8 key:
  • buy a new 6 button relay (on/off) keypad from Insteon when they're scheduled to be back in stock in January
  • Remove the 8 key keypad facia from your existing  2334-222 dimmer key pad and screw it on to the new relay keypad
  • Look around page 16 of the Insteon keypad manual.. there are the directions for reconfiguring the new 6 key relay as an 8 key relay. The manual details all of the steps described above
Edited by paulbates
🤯 I had no idea this was possible.  That is amazing.  Even better that it could be done with a device in place. WOW thank you.
  • 5 weeks later...
Want to come back and say I followed the suggestions of paulbates and it worked 100%.
Thank you!
