Only press / hold triggers are activating, not simple press
Hello,
I've had this running using the original 40 IR codes for over a year now, and it has worked great.
About 2 months ago, we noticed the simple "press" triggers quit working.
I have 3 triggers setup for each IR code:  "Pressed"  "Held", and "Released".
Held and Released appear to be working, but the simple Pressed do not do anything.
I did connect a laptop to the Flirc and I can see simple codes come in upon press, and also see them repeat when I hold the button on my remote.
Is there a way I can get "Pressed" working again?
Thanks for any help you can provide!!
Set "Release threshold" to 50. I will release a new version with lower default value. Seems it's causing more problems than it solves.
