New Web Control 832 ver 1.02 Configuration
What is the purpose of the double inputs for configuration setup.  Only difference I can see between the two sets is the Familair Name and custom Name ?
Sorry, not following. Can you Screenshot. I am not seeing double inputs in the config setup in PGx.
I did some renaming of the custom params between v1.0.1 and 1.0.2, did you upgrade from a previous version or did you install fresh the 1.0.2 version?
-Tim
Here is the inputs screen for config for web 8/32.  Had to fill out the second section to get it to update the data on polisy.
Just saw your second question. I did an install from the notification page, i assume that is a fresh install. Had to reenter the parameters in config.
Wow. Never have seen that before! The bottom half should be all that is displayed. I would delete the plugin and reinstall. Its almost like there was left over artifacts between original install and update. Try a delete and reinstall and let me know.
-Tim
