"Could not get Variable Params" error
I have my lights schedule to dim at various times in the evening.  For the past two nights, the 9 o'clock program that was supposed to dim the lights has not worked.  The first time it happened, I used the UD mobile app to trigger the "Run Then" option for the program which then ran the program and the lights dimmed.  Last night, when the same thing happened, I triggered the "Run Then" option and got the following error message "Could not get Variable Params".
I resynced the mobile app.  Rebooted the eisy. I resynced again.  None of these steps would make the error go away.  I used the IoX Launcher to bring up the Java interface and I was able to trigger the program correctly then.
I can control the devices on the system with no issues, so I know it's not a communication program with between the eisy and UD Mobile.
Any thoughts on how to troubleshoot?
Solved by Javi
I experience the same thing last night as well. Rebooted, resynced, no change. Submitted a ticket and got a reply saying that a new update to UD Mobile is about to show up on the App Store.
Update is now available on the App Store and appears to work!
I agree, had the same problem, updated the app, problem is gone. Thank you..
