UD2)17rrh Posted January 16 Posted January 16 Hi. Bringing back an issue I had some time ago but did not resolve. EISY and Polygot 3 show that the Hue install was successful. That is, I see a green "connected" status in Polygot. However I do not see any Hue devices added when I review my admin console. I tried a reboot of the system along with several attempts with "re-discover bulbs". Any thoughts? Anything obvious I am missing? Many thanks. Quote
dbwarner5 Posted January 17 Posted January 17 @UD2)17rrh If the Plug-in is installed and running, and nothing is showing in the AC, then we need to start with checking to see if the PI has the light bulbs and is connecting to your Hue Hub first. Open PGX and then hit Details on the Hue. Then hit Nodes. Is there anything listed? You should see all of your bulbs AND your Hue Hub. Is just the Hub showing? and if so does it say for the State (ST) a value of 1 for true. See below. If not, then it hasn't connected with your hub correctly. Here are the instructions from the README for the HUE. Once installed - push the button on the Hue Bridge and add NodeServer into Polyglot, that will allow it to pair with the Bridge. Sometimes automatic bridge IP address discovery fails, in that case - you can specify Bridge IP address in a custom parameter ip for the NodeServer using Polyglot's frontend interface. Notes Poly assumes that Bridge IP address never change, so it is recommended that you create an IP address reservation for the Hue Bridge on your router. If you do see your hub but no lights, or if your Hub is not connected, then you may want to uninstall the Plug-in and then re-install it and try again. Follow any prompts upon installation to press the Hue button. However if you DO SEE your lights and hub listed then it's a problem between the PGX and EISY and linking into the AC. If that is the case, be sure to close your AC, then go to the HUE log in PGX and change it DEBUG and then stop the Plugin and then restart it. Open up the AC and see if it shows. If not, download the log and post it. As a side note, in the AC, everything will be grouped under the Hue Hub. So be sure to expand it to look for your lights. You can right click and ungroup them if that is the case and they will show in the tree. An easy way to look for your Hue hub is to click on MyLighting and then click on the column labeled Address. Then scroll down to the node server number. In my case below it's loaded in slot 3 so it is easy to find that way. 1 Quote
UD2)17rrh Posted January 18 Author Posted January 18 Thanks for the reply @dbwarner5. So I see the Hub just as the screenshot above shows (yes, State (ST) is a value of 1). But no Hue bulbs. I removed the plug-in and reinstalled it. As above, everything looks good (ST = 1) but still no bulbs. Quote
dbwarner5 Posted January 18 Posted January 18 Ok. Then let’s eliminate one more step backwards. are the bulbs showing up in the Phillips hue app? Meaning are the bulbs themselves connected to the hub? we need to verify that before we work on why the plug in , which is connected to your hub, doesn’t have the bulbs. thanks 1 Quote
oberkc Posted January 18 Posted January 18 Shot in the dark....unlikely, I suspect...but is it possible that you have installed the Hue "Emulator" rather than the Hue Quote
UD2)17rrh Posted January 18 Author Posted January 18 @dbwarner5 yes, my Hue iOS app sees all my Hue bulbs and accessories. @oberkc Yes, Hue installed and not the emulator. Thanks for helping. Quote
dbwarner5 Posted January 18 Posted January 18 So progress. We have now narrowed it to the plug in. One more thing to try: 1) while you have the plug in open and looking at the nodes, unplug your hue hub. The plug in should change to state 0. plug the hub back in and it should change back to 1 just want to be sure it’s actually seeing your hub. You may have to restart the plug in for the state to change. but before you do that can you change the log to debug? then after it runs for a bit , download the log file and post it thanks Quote
dbwarner5 Posted January 18 Posted January 18 Just curios, what are the names of your lights in the hue hub / app? Quote
UD2)17rrh Posted January 18 Author Posted January 18 Thanks. Here is the log: 2025-01-18 12:30:54.604 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-01-18 12:30:54.606 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-01-18 12:30:54.606 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-01-18 12:31:09.615 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-01-18 12:31:09.616 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-01-18 12:31:09.616 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-01-18 12:31:24.622 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-01-18 12:31:24.622 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-01-18 12:31:24.622 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-01-18 12:31:39.631 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-01-18 12:31:39.631 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-01-18 12:31:39.632 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-01-18 12:31:41.796 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-01-18 12:31:41.796 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-01-18 12:31:41.796 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot 2025-01-18 12:31:54.641 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-01-18 12:31:54.641 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-01-18 12:31:54.642 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-01-18 12:32:09.647 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-01-18 12:32:09.647 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-01-18 12:32:09.647 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-01-18 12:32:24.653 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-01-18 12:32:24.653 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-01-18 12:32:24.653 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-01-18 12:32:39.657 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-01-18 12:32:39.657 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-01-18 12:32:39.658 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-01-18 12:32:41.800 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-01-18 12:32:41.801 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-01-18 12:32:41.801 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot Quote
UD2)17rrh Posted January 18 Author Posted January 18 3 hours ago, dbwarner5 said: One more thing to try: 1) while you have the plug in open and looking at the nodes, unplug your hue hub. The plug in should change to state 0. plug the hub back in and it should change back to 1 just want to be sure it’s actually seeing your hub. You may have to restart the plug in for the state to change. The state did not change to 0 when I unplugged my Hue hub. Quote
dbwarner5 Posted January 18 Posted January 18 @UD2)17rrh thanks. Sorry for the continued trouble. I actually just unplugged my Hue Hub as well. No change. So wonder if the plug in is going directly to the Hue Server, once it connects with the Hub the first time. Was worth a test. So lets continue with some basics... what software versions are you on for both the Eisy and PGX? I think the latest is 3.3.17 for pgx and 5.8.4 for Eisy. Hit Upgrade packages in the Admin console and wait until it updates to the latest versions if you are not there. Once updated, you may want to try and again, uninstall and reinstall the Hue Plug in..when you do this, does it ask you to push the button on your hub? If so, and it still doesn't work, I saw in some of the other Hue posts that stop/ starting of the plugin a few times may be necessary to get all the lights in. In a different Plug in, there was an issues once of special characters used in the name of the devices which the plugin couldn't handle. Just throwing out some more ideas to try. Lastly, I have also noticed with PGX that if you are in the screen and restart the plug in, it wont show the Nodes, until you go back to the Dashboard of PGx and then back into the Plug in. Lastly, can you change the log to Error and after a few tries of restarting, download it? Thanks. Quote
UD2)17rrh Posted January 19 Author Posted January 19 Thanks @dbwarner5 for your help. Currently running PG3x v 3.2.27. IoX running 5.8.4. It has been for a while. I previously did delete the plug in and reinstall. I did not get the request though to press the button on my hub. I also tried starting and stopping the plug in. No success at this time. Here is a portion of the error log...thanks again. 2025-01-18 22:16:33.799 MainThread udi_interface.interface WARNING interface:start: No node server version specified. Using deprecated server.json version 2025-01-18 22:16:33.800 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b9026579_3.cert key: 0021b9026579_3.key ca: /usr/local/etc/ssl/certs/ud.ca.cert 2025-01-18 22:16:33.800 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: huebridge not found in database. 2025-01-18 22:16:33.800 MainThread udi_interface.interface INFO interface:addNode: Adding node Hue(huebridge) [None] 2025-01-18 22:16:33.800 MainThread udi_interface INFO hue:__init__: Started Hue Protocol 2025-01-18 22:16:33.801 Interface udi_interface.interface INFO interface:_startMqtt: MQTT keepalive is 300 seconds. 2025-01-18 22:16:33.850 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success 2025-01-18 22:16:33.850 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:65:79_3 - MID: 2 Result: 0 2025-01-18 22:16:33.892 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 2. Reason codes: ['Granted QoS 0'] 2025-01-18 22:16:33.975 Thread-2 (parameter_handler) udi_interface INFO hue:connect: Saved bridges information is not found 2025-01-18 22:16:33.975 Thread-2 (parameter_handler) udi_interface INFO hue:connect: No bridge configuration found, trying discovery... 2025-01-18 22:16:33.976 Thread-2 (parameter_handler) udi_interface INFO phue:connect: Attempting to connect to the bridge... 2025-01-18 22:16:33.976 Thread-2 (parameter_handler) udi_interface INFO phue:connect: Error opening config file, will attempt bridge registration 2025-01-18 22:16:34.008 Thread-2 (parameter_handler) udi_interface INFO phue:get_ip_address: Connecting to discovery.meethue.com/ 2025-01-18 22:16:34.055 Thread-2 (parameter_handler) udi_interface ERROR hue:connect: IP Address OK. Node Server not registered. Quote
firstone Posted January 19 Posted January 19 10 hours ago, UD2)17rrh said: 2025-01-18 22:16:34.055 Thread-2 (parameter_handler) udi_interface ERROR hue:connect: IP Address OK. Node Server not registered. When you see this, you should usually see the notice on dashboard saying "Please press the button on the Hue Bridge(s) and restart the node server within 30 seconds". If you're not getting a notice there would be something wrong on pg3 side. But either way, try to do it. 1 Quote
dbwarner5 Posted January 19 Posted January 19 A few other things you may want to try: 1) delete and re-install, but pick a different slot number 2) per the directions, if you know your hub IP, you can add it: Sometimes automatic bridge IP address discovery fails, in that case - you can specify Bridge IP address in a custom parameter ip for the NodeServer using Polyglot's frontend interface. 3) following Firstone's thoughts, he indicates pressing the hub button and THEN restarting the plugin. After that, I am out of ideas!! Quote
dbwarner5 Posted January 19 Posted January 19 @UD2)17rrh Just thought of one other possibility>. Is your Eisy on Wifi? If so, I found with a different plug in, that the Eisy makes its own Subnet on your LAN when connected via wifi, which wont allow it to find your Hue hub. If you can add the IP address of your Hue hub into the Plugin, this may solve the issue. If not, if you can temporarily connect your eisy via ethernet (which will require a reboot), and try the plug in, this will at least identify what the problem is. Good luck. Quote
UD2)17rrh Posted January 19 Author Posted January 19 Thank-you @dbwarner5 and @firstone for your help. So I am afraid to say (aka embarrassed) that this was operator error on my part. I pressed the Hue Hub button and immediately restarted the plug-in. Within a few seconds everything populated. Thank-so much for your help. I also see all my Hue bulbs in my admin console, and I am happy to start programming. 2 Quote
dbwarner5 Posted January 20 Posted January 20 YEA!!! the directions aren't clear about that, so no problem. Glad it worked out because I was out of ideas! cheers. Quote
jtara92101 Posted January 30 Posted January 30 (edited) I'm facing a similar issue, and having trouble following this. What's different is that from a few days ago, I'm suddenly unable to affect the state of bulbs from the AC. (Or from linked Insteon buttons, which is how I discovered this...) I got notices in the log about groups and bulbs not existing. And also a Python error with traceback. (wish I'd saved that...) I decided to re-install the Hue plugin, and I installed on a different slot, because of tips here. Now I'm in the condition where PG sees the bridge, and the bridge is connected. I can't get it to populate the bulbs. Hub button, restart, still only shows 1 node, the bridge. As with OP, I got no request to push the button (when I tried it without pushing the button first). I did add the hub IP address, though it works (such as it is) either way. A really detailed how-to would be useful, vs. the very terse comments in the README. Edited January 30 by jtara92101 Quote
firstone Posted February 25 Posted February 25 Do you see all bulb in a hue app? The process is not really that complicated - if you have installed into new slot, the configuration would not carry over. On start up, node server would try to authenticate. It can only do it if button is pressed. If it's not, it should publish a notice. Try to restart and maybe post some of the log around restart. Quote
