boto3 import fails
hi
I get the following message after installing with a VUE3 device
2025-01-25 22:22:54.449 MainThread udi_interface ERROR udi_interface:write: import boto3
2025-01-25 22:22:54.449 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError
2025-01-25 22:22:54.449 MainThread udi_interface ERROR udi_interface:write: :
2025-01-25 22:22:54.450 MainThread udi_interface ERROR udi_interface:write: No module named 'boto3'
any ideas?
Solved by bpwwer
Unfortunately, because of the way Python works (and Python is what most plug-in's are written in), it sometimes needs things that are part of the development packages on the Polisy/eisy.
Most Python packages are available for the OS that the Polisy/eisy is built on in ready to be used form, but some are not and typically are available in source only form.  When they are only available in source form, they need to be compiled on the Polisy/eisy to be used.  To compile them, we need the compilers installed and they only get installed if you install the dev packages.
