i3 Keypads
Does anyone use these with IoX that can give me.some.advice? They have been a hot.mess for me.to get working correctly.  They seem to program fine but then don't work as expected. Mostly the indicator lights. But sometimes other things as well.
With some scenes the indicator lights are perfect. Other scenes and the indicator light flashes when pressed a couple of times then off. Now all the buttons are set as toggle on so Tha shouldn't happen
I have yet to figure out the backlight settings. They don't appear to do anything.
It's like the isy thinks the devices are programmed but in reality they aren't fully programmed.
Here ya go
Also of note, these keypads have no loads attached.  Just using them for scenes.
I haven't used the i3 keypad, but having used the PS-01, some surprising behavioral tweaks are under the flags 'node' associated with each device.
The out-of-the-box flags can vary and odd sometimes. Out of my ~20 PS-01s, a number of them were set to 'Disable RF'(???). I also had to factory reset a couple initially because of behavioral problems, but have been fine since.
Note that my experience is that ,'Restore Device' does not put flags back on the device.
Edited by paulbates
I have factory reset them multiple times. Then restore device.  They actually work better PRIOR to the restore device.   And the devices work great when the scene is activated by the AC.
