Moving LiFX to eISY - discovery not working
I have an old pg2 instance running LiFX, which I'm finally ready to move to eISY's polyglot.  I am using a devlist.yml file, as auto discovery is not reliable.  I've put my devlist.yml into the nodeserver directory and changed the owner, but every time I start the NS, discovery ends with this (different bulb/mac address each time):
2025-02-18 09:48:54.077 Thread-4 (_discovery_process) udi_interface      ERROR    lifx-poly:_discovery_process: discovery Error: WorkflowException: Did not receive [<class 'lifxlan.msgtypes.StateVersion'>] from d0:73:d5:75:67:e6 (Name: None) in response to <class 'lifxlan.msgtypes.GetVersion'>
If I remove the devlist file, it attempts auto discovery (and gets some bulbs) - so it is seeing the file, but it's not working.  My devlist file is fine, it's a direct copy of what is in production today.  Help?
  • 5 months later...
Hi @skunkiechris, I am curious if you figured anything out. I had 4 older (2018ish) bulbs that were working great with the devlist but one of them finally gave up and died recently. I just picked up a new bulb and I am seeing the same error that you list above. The other 3 older bulbs are still working properly and reporting status.
