EISY will not connect to Serial PLM 2413s
New EISY user
I'm upgrading from 994 to EISY
The existing PLM is working with my old 994 - PLM info/status 3c.48.85 v9E / connected
But when I connect it with a correctly wired FDTI USB cabled (pins 1 orange RX, 7Black GND, 8 yellow TX) - the eisy  PLM info/status 0.0.0 V0 / Not connected
I'm wondering if the problems I had upgrading the packages on my EISY has messaged up the OS.  I had to use SSH commands to update the packages so now I'm trying to use SSH to see the FDTI chip in the USB-Serial cable.
Using Putty - SSH, I see the FDTI adapter is recognized by the EISY:
ugen0.2: <FTDI USB-RS232 Cable> at usbus0
uftdi0: <FTDI USB-RS232 Cable, class 0/0, rev 2.00/6.00, addr 3> on usbus0,
But I see the FDTI USB-RS232 UART is disconnected:
ugen0.2: <FTDI FT232R USB UART> at usbus0 (disconnected)
Should the FDTI FT232R USB UART at usbus0 be disconnected?  I've not played around enough with this system to know - nor do I really know much about this OS.  Any help is appreciated.
Below is the SSH session
[admin@eisy ~]$ dmesg | grep -i usb
xhci0: <XHCI (generic) USB 3.0 controller> mem 0x6001100000-0x600110ffff at devi                       ce 20.0 on pci0
usbus0 on xhci0
usbus0: 5.0Gbps Super Speed USB v3.0
ugen0.1: <Intel XHCI root HUB> at usbus0
uhub0 on usbus0
uhub0: <Intel XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
Root mount waiting for: usbus0 CAM
ugen0.3: <vendor 0x8087 product 0x0026> at usbus0
uftdi0: <FTDI FT232R USB UART, class 0/0, rev 2.00/6.00, addr 1> on usbus0
ubt0: <vendor 0x8087 product 0x0026, class 224/1, rev 2.01/0.02, addr 2> on usbu                       s0
[admin@eisy ~]$
Edited by tokenworker
correct plm model number
I had problems connecting to my PLM when I first set my eisy up. I had to unplug/replug the PLM, wait 10 seconds, and then unplug/replug the eisy a couple of times. Then it connected and it has been fine since
I
I power cycled the EISY and PLM and moved the USB FDTI Serial cable adapter to the back USB Port of the EISY.
Now when I execute same command, I don't see "disconnected" so I'm guessing the USB ports on the EISY only check for devices during power up?  (at least I don’t see disconnected).  However, When I query the PLM using Tools->PLM status I see “0.0.0 v0 / Not Connected”
I'm tempted to buy new PLM but this PLM still seems to communicate with my 944 box Tools->PLM status I see “3c.48.85 V9E / Connected”   So it appears the PLM is still OK.     What should I try next?  I could hook up a scope to the TX serial lines - to see if the FDTI chip is sending data or if the PLM is trying to do the same.  Thoughts?
Here is the
xhci0: <XHCI (generic) USB 3.0 controller> mem 0x6001100000-0x600110ffff at device 20.0 on pci0
usbus0 on xhci0
uhub0 on usbus0
uftdi0: <FTDI USB-RS232 Cable, class 0/0, rev 2.00/6.00, addr 1> on usbus0
ubt0: <vendor 0x8087 product 0x0026, class 224/1, rev 2.01/0.02, addr 2> on usbus0
Update - Problem Resolved.  I had two issues.
1.) The EISY seems to require a reboot - or better yet, power cycle - to recognize the USB FDTI Serial cable AND connect a serial port.  During my early attempts to connect the PLM to the EISY,  I was not power cycling after inserting the USB Serial PLM cable - and it looked like the EISY was seeing via SSH "dmesg | grep -i usb" commands but there was a message about being disconnected.  See below session with disconnected in red
2.) I had a DIY FDTI Serial PLM cable.  I tried to save some money, but I spent a lot more of my time and probably should have just purchased the cable from the start.
Thanks to UD tech support for confirming my EISY was operating correctly.  Now I need to complete the migration process.  Its all downhill from here, right?  What could go wrong :)
I believe if the (disconnected) message shows in response to this command, power cycle the EISY to get it to properly set up the FDTI device and open the UART (com/serial) port.
usbus0 on xhci0
uhub0 on usbus0
[admin@eisy ~]$
