Arm Zero Entry Not Working anymore
Odd issue - all of the sudden I can't use the arm zero entry anymore.   I watch my panel when it runs, I see the light go off like its getting the command, but then instead of hearing the normal beeps and then after exit delay seeing the red armed light, it just goes back to green.  I see this in the log:
2025-03-18 06:06:48.728 Command udi_interface INFO nodes:arm_zero_entry: Arming partition 1 in zero_entry mode in arm_zero_entry()...
Then see nothing.  I can toggle the chime, I can set other armed modes (Stay, etc.), but this no longer works.
Any help would be appreciated!
It looks like clicking the button in IoX is calling the correct piece of code, and the plugin is subsequently sending the  right command to the EVL successfully. The recent update didn't change this particular piece of code, or any of the code for the partition node.
Some things to clarify:
1. Do ALL of the other arming options work?
2. Have you recently updated your EVL firmware?
3. Have you set the logging level for the plugin to "Debug" and retried to see what additional info there is?
NOTE: I believe the three, identical log entries is a bug in the PG3x front-end ("Dashboard") and not something actually being produced by the plugin. This can be confirmed if you are seeing every log entry repeated three times.
As far as I know, I have not updated the firmware (unless something can do that without me manually doing something).  Here is the debug logs on trying zero entry.
2025-03-18 08:09:43.591 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-03-18 08:09:43.591 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-03-18 08:09:43.591 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-03-18 08:09:43.592 Thread-66670 (_poll_handler) udi_interface DEBUG evldscns:shortPoll: In shortPoll()...
2025-03-18 08:09:43.592 Thread-66670 (_poll_handler) udi_interface DEBUG evltpi_dsc:sendCommand: Sending command to EnvisaLink device: Command 008, Data
2025-03-18 08:09:43.592 Thread-66670 (_poll_handler) udi_interface DEBUG evltpi_dsc:_send_cmd: In _send_cmd(): Command 008, Data
2025-03-18 08:09:59.956 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message command
2025-03-18 08:09:59.956 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING command
2025-03-18 08:09:59.956 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS command message {'address': 'partition1', 'cmd': 'ARM_ZEROENTRY', 'query': {}} from Polyglot
2025-03-18 08:09:59.956 Command udi_interface INFO nodes:arm_zero_entry: Arming partition 1 in zero_entry mode in arm_zero_entry()...
2025-03-18 08:09:59.956 Command udi_interface DEBUG evltpi_dsc:sendCommand: Sending command to EnvisaLink device: Command 032, Data 1
2025-03-18 08:09:59.956 Command udi_interface DEBUG evltpi_dsc:_send_cmd: In _send_cmd(): Command 032, Data 1
2025-03-18 08:10:13.586 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-03-18 08:10:13.587 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-03-18 08:10:13.587 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-03-18 08:10:13.587 Thread-66671 (_poll_handler) udi_interface DEBUG evldscns:shortPoll: In shortPoll()...
2025-03-18 08:10:13.587 Thread-66671 (_poll_handler) udi_interface DEBUG evltpi_dsc:sendCommand: Sending command to EnvisaLink device: Command 008, Data
2025-03-18 08:10:13.587 Thread-66671 (_poll_handler) udi_interface DEBUG evltpi_dsc:_send_cmd: In _send_cmd(): Command 008, Data
2025-03-18 08:10:43.593 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-03-18 08:10:43.593 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-03-18 08:10:43.593 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-03-18 08:10:43.593 Thread-66672 (_poll_handler) udi_interface DEBUG evldscns:shortPoll: In shortPoll()...
2025-03-18 08:10:43.593 Thread-66672 (_poll_handler) udi_interface DEBUG evltpi_dsc:sendCommand: Sending command to EnvisaLink device: Command 008, Data
2025-03-18 08:10:43.593 Thread-66672 (_poll_handler) udi_interface DEBUG evltpi_dsc:_send_cmd: In _send_cmd(): Command 008, Data
When I do "Arm Stay" (unlike the Arm Zero Entry) the alarm panel immediately beeps and turns red to arm.  Here is that log
2025-03-18 08:14:09.530 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message command
2025-03-18 08:14:09.543 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING command
2025-03-18 08:14:09.544 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS command message {'address': 'partition1', 'cmd': 'ARM_STAY', 'query': {}} from Polyglot
2025-03-18 08:14:09.544 Command udi_interface INFO nodes:arm_stay: Arming partition 1 in stay mode in arm_stay()...
2025-03-18 08:14:09.544 Command udi_interface DEBUG evltpi_dsc:sendCommand: Sending command to EnvisaLink device: Command 031, Data 1
2025-03-18 08:14:09.544 Command udi_interface DEBUG evltpi_dsc:_send_cmd: In _send_cmd(): Command 031, Data 1
2025-03-18 08:14:13.608 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-03-18 08:14:13.608 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-03-18 08:14:13.608 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-03-18 08:14:13.608 Thread-66679 (_poll_handler) udi_interface DEBUG evldscns:shortPoll: In shortPoll()...
2025-03-18 08:14:13.609 Thread-66679 (_poll_handler) udi_interface DEBUG evltpi_dsc:sendCommand: Sending command to EnvisaLink device: Command 008, Data
2025-03-18 08:14:13.609 Thread-66679 (_poll_handler) udi_interface DEBUG evltpi_dsc:_send_cmd: In _send_cmd(): Command 008, Data
2025-03-18 08:14:43.607 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-03-18 08:14:43.607 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-03-18 08:14:43.608 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-03-18 08:14:43.608 Thread-66680 (_poll_handler) udi_interface DEBUG evldscns:shortPoll: In shortPoll()...
2025-03-18 08:14:43.608 Thread-66680 (_poll_handler) udi_interface DEBUG evltpi_dsc:sendCommand: Sending command to EnvisaLink device: Command 008, Data
2025-03-18 08:14:43.608 Thread-66680 (_poll_handler) udi_interface DEBUG evltpi_dsc:_send_cmd: In _send_cmd(): Command 008, Data
Arm Away does the same thing, works, and then I get the countdown beeps for exit delay.
The plugin is successfully sending the correct codes for Armed Zero Entry and Armed Stay to the EnvisaLink. If one is working and one is not, I have to believe it has something to do with your DSC Panel configuration (I know you won't believe that). Try Arming your system with Zero Entry from your alphanumeric keypad. Does it work? Does it ask for a passcode? If you arm for Stay or Away from the keypad, does it ask for a passcode then?
OK, this morning when I got up, decided to do some messing with it.  Noticed this morning that even though I manually set the alarm last night (in Zero Entry), on the AC, Partition 1 of the Alarm Panel was showing Ready.  No errors in the log that I could see.  I ended up restarting the node server for DSC and now everything works . . .  Something had to be whacked on the Polyglot side . . .  Very odd.  Thanks for your help, but this looks like something was just off, can't tell what it was.
