Initial testing of Beta Plug-in
I did find an issue with the dimmer and also with the rgb bulbs. Those have been corrected in version 1.0.9, which I have submitted to the non-production store.
See if this version behaves a bit better when setting levels.
I still need to investigate why it seems to stop getting updates from the devices after a day or two.
My disconnects seem to be related to number of commands.
try to use the AC and adjust your light 10-20 times and see if you disconnect
  • 1 month later...
HI.. am wondering if there is any movement on this ?
Just played with it again, and works for a few commands and then stops working.
Restart of the plug-in resolves it and then it works again for ~5-10 commands and then stops.
I had a problem (again) with my Samsung Smartthings / meross link and meross was able to solve it (this time) so I asked if there was anyone that could help you with their API to finish development. No answer..(
Not really. I haven't been able to find anything incorrect in the plug-in.
What seems to happen is that after sending a few commands to the device, the device just stops responding and doesn't send anything else to the plug-in after that. I see this after about 3 days and I send commands to my bulb device 2 time a day, so that seems to match what you're seeing.
I wonder if it's a race condition between polling the device for updates and sending commands. It may be possible that a poll happens while the command is waiting for a response. I guess one way to test this would be to increase the polling interval from 60 seconds to something really big like 6000 seconds and see if that helps.
So just ran an experiment. I changed short poll to 6000 and was able to do at least 30 on/off cycles without any issues. Then I changed the short poll to 20 seconds and it failed after 3 or 4 on/off cycles, well it set the on-level to 0 so on stopped working. So I'm not sure that's the same failure. I've set my short poll to 600 now and I'll let it run and see if it fails after a few days.
