Blue Memory light flashing slowly
I just started having trouble accessing my ISY through MobiLinc so I went downstairs to check the ISY and noticed the blue memory light is flashing (maybe once every 4 or 5 seconds).
I can access the Admin Console through my desktop and control the lights  and all my programs are running fine but I can’t connect with MobiLinc and the flashing light suggests something is not working.
Any thoughts? Thx in advance
Solved by birdman
Flashing blue is a SD memory card issue.
Try reseating the SD card issue. It can be cleaned with a pencil eraser before reseating
If its an older ISY 994i, chances are the card needs to be replaced
Edited by paulbates
Thx. I have a 994i and there is no SD card in the slot. Never had one. Just now this morning both the Blue memory and Red error light started flashing together - continuous flash off and on. I unplugged and plugged it back in but still flashing.
Edited by birdman
Figured it out. I see that when both lights are flashing that seems to suggest it could be a network issue. I changed the Ethernet plug connecting the ISY to my switch and that seems to have solved it. I didn’t think Ethernet cables go bad but this one seems to have a damaged clip on the end so wasn’t seating properly. I think this fixed it. Thx.
With out an SD card it should be impossible to even use it as it is where all the module information and programming is stored.
I believe the early versions of the ISY994i had it internally and you have to remove the top.
Very interesting. I have had this ISY 994i for a long time and while there is a micro SD slot in the front I have never put one (and it sure doesn’t look like it has one inserted into the slot).
 I had to take the top off mine to get to the SD card. Mine didn't align up well with the slot and when I clicked it to remove it fell into the unit. 😀
