Modifying scenes On Level in app
Is this feature going to be implemented any time soon? all I could find about it here was an almost 2 years old closed topic saying that there's plans on implementing it, but no actual updates on it or even an estimate.
Solved by Javi
It's still on our list, but can be done from the Admin Console.
Scenes in version 5.x are much more complex than Scenes in 4.x (see the 5.x fan example).  Also for insteon the Scene information is written to the Controllers/Responders so may take some time depending on the number of changes.
Each Scene-Controller-Settings has an on-level setting for each responder in the Scene.  The Scene-Settings also has an on-level setting for each responder in the Scene.  So changing the on-level for each Responder manually may not be intuitive or may not work as desired without changing many properties.
So, if you set the Scene-Settings on-levels' for each responder, it will only work if you trigger from eisy. Setting on-levels from a Scene-Controller-Settings will only work when triggered from that Controller.
What are you trying to do?   There may be another way to accomplish the same without getting too deep into the settings every time a change is needed.
It's just that it's way more practical to modify scene levels from an app than going around the whole place with a laptop. Thank you for your reply.
