Thermostat Setting Error
I’ve got a thermostat set up in UD Mobile on both my iPhone and iPad. When trying to tap the UP or DOWN arrows to change the cool or heat set point, I’m getting an error:
<?xml.version=“1.0”
encoding=“UTF-8”?><RestResponse
succeeded=“false”><status>400</status>
<reason code=“2101”/></
RestResponse>
I can tap on the temperature and get the pop up menu with values and select one. Verified the app updated 2 days ago and I noticed the error around that time. I’ve rebooted my EISY, iPhone and iPad, and run the Synchronize in the app. No change, always get the above error.
Solved by Javi
At 1.2.7.  I’m checking for update right now.
Update to 1.2.8, the issue appears to be resolved!  Thanks!
