Upgraded 5.9.1_18. No URL to click in GUI
Upgraded, rebooted, ensured Im on latest Java version, cleared app in Java, downloaded new Start file.  I also can also ssh admin@<IP> at the command line.
I can connect with phone via UD Mobile and from web app in Portal.
When I open the Admin GUI, it wont list the EISY url that I can click on to connect to.
Any recommendations before I open ticket?
Sysconfig File below
*** OS ***
FreeBSD eisy 14.1-RELEASE-p6 FreeBSD 14.1-RELEASE-p6 #4 releng/14.1-n267727-74b6c983723c-dirty: Fri Nov 15 12:13:25 PST 2024     root@bsdev14.isy.io:/usr/obj/usr/src/amd64.amd64/sys/eisy amd64
*** Package Information ***
************ UDX ************
udx-3.9.0_9
Version        : 3.9.0_9
Installed on   : Thu Jun 19 16:07:42 2025 EDT
Origin         : misc/udx
Architecture   : FreeBSD:14:amd64
Prefix         : /usr/local
Categories     : misc
Licenses       :
Maintainer     : michel@universal-devices.com
WWW            : UNKNOWN
Comment        : Polisy/eisy Admin Service
Shared Libs required:
	libsqlite3.so.0
	libmosquitto.so.1
	libcurl.so.4
Annotations    :
	FreeBSD_version: 1401000
	repo_type      : binary
	repository     : udi
Flat size      : 19.9MiB
Description    :
UDX HW/Admin Service for Universal Devices eisy/Polisy
<strong>Release notes for 3.9.0_9 - 03/21/2025</strong><br/>
- Install dhcpcd during upgrade to 141
<strong>Release notes for 3.9.0_8 - 03/16/2025</strong><br/>
- Wait for network/sanity check
<strong>Release notes for 3.9.0_6 - 02/24/2025</strong><br/>
- Change pydantic to pydantic2
<strong>Release notes for 3.9.0_5 - 02/20/2025</strong><br/>
- Fixed Wifi setup
<strong>Release notes for 3.9.0_4 - 02/16/2025</strong><br/>
- Fixed mdns responder on polisy <br/>
- Fixed devd for polisy <br/>
- Fixed hostname for eisy <br/>
<strong>Release notes for 3.9.3 - 02/07/2025</strong><br/>
- MAJOR UPGRADE to OS 14.1 - WILL REBOOT MULTIPLE TIMES. DO NOT POWEROFF <br/>
- Fixed bootloader upgrade for 14.1 <br/>
- Change isy userid to polyglot <br/>
- Power button no longer performs upgrades<br/>
- Using ud repo for FreeBSD packages<br/>
- Initial IoX Matter Bridge scafolding<br/>
<strong>Release notes for 3.6.5_2 - 11/19/2024</strong><br/>
- Major upgrade to OS 14.1<br/>
- Cleaner daemon operations<br/>
- Support for eisyui (Unified/Universal eisy UI) <br/>
<strong>Release notes for 3.5.8 - 07/23/2024</strong><br/>
- Fixed upgrade failure bug<br/>
- Fixed tpm and sleep issues<br/>
- Fixed warning for upgrade to 14.x <br/>
************ IoX ************
isy-5.9.1_18
Version        : 5.9.1_18
Installed on   : Thu Jun 19 16:07:33 2025 EDT
Origin         : misc/isy
Prefix         : /usr/local
Categories     : misc
Licenses       :
WWW            : UNKNOWN
Comment        : ISY Port to X (IoX)
	libxml2.so.2
	libwebsockets.so.19
	libsqlite3.so.0
	libmosquitto.so.1
	libiconv.so.2
	libgobject-2.0.so.0
	libgmodule-2.0.so.0
	libglib-2.0.so.0
	libgio-2.0.so.0
	libcurl.so.4
	libarchive.so.13
Annotations    :
	repo_type      : binary
	repository     : udi
Flat size      : 39.4MiB
Description    :
ISY Service for Universal Devices Running on X (IoX)<br/>
<strong>Release notes for: 5.9.1_17 - 03/14/2025</strong><br/>
Fixes:<br/>
 - Fixes for isy permissions
<br/>
<strong>Release notes for: 5.9.1_15 - 03/14/2025</strong><br/>
Fixes:<br/>
 - Support PIN codes for Zigbee locks
<br/>
<strong>Release notes for: 5.9.1_12 - 03/07/2025</strong><br/>
<strong>Release notes for: 5.9.1_11 - 03/07/2025</strong><br/>
Fixes:<br/>
 - In some cases a corrupted file was causing IoX to crash <br/>
 - Fix file permissions for scripts when installing IoX
 - Don't process battery devices when doing network heal (queue them instead)
 - Don't attempt to interview battery devices during migration
<br/>
<strong>Release notes for: 5.9.1_9 - 02/20/2025</strong><br/>
Fixes:<br/>
 - Dynamic Profiles: Allow and ignore blank or numeric 'init' on command parameter<br/>
 - Dynamic Profiles: Make sure profile entry in common db is updated after any profile move<br/>
<br/>
<strong>Release notes for: 5.9.1_8 - 02/10/2025</strong><br/>
Fixes:<br/>
 - Dynamic Profiles:  Show parsing errors in log when moving profile files to database<br/>
<br/>
<strong>Release notes for: 5.9.1_7 - 02/09/2025</strong><br/>
Fixes:<br/>
 - Programs: Fixed problem where node status changes caused control conditions to run (only affected node server nodes)<br/>
 - ZWave: Fixed problem where Z-Wave migration would fail to migrate any Z-Wave devices<br/>
 - Zigbee: Fixed problem of nodes not being created for devices with multiple buttons<br/>
 - Insteon: Fixed problem where some commands were missing from inlineLinc devices<br/>
 - Insteon: Fixe problem where Insteon would stop responding (usually caused by using I3 Dial)<br/>
<br/>
Features:<br/>
 - Matter:  Hello World!  Light bulb support<br/>
 - Zigbee: Support Relative Humidity and Temperature Measurement Clusters<br/>
 - Zigbee: Support thermostats<br/>
 - Insteon: LED Control for I3 Dial and I3 Paddle<br/>
 - Programs:  Added 'Unix Date/Time (seconds)' to the set of system values you can assign to a variable<br/>
 - Admin Console: Log Viewer and Capture for Matter, Zigbee, Z-Wave, and other logs<br/>
<strong>Release notes for: 5.9.0_x - 11/11/2024</strong><br/>
- New lightweight daemon<br/>
- Support for Matter<br/>
- Support for eisyui<br/>
<strong>Release notes for: 5.8.4_3 - 07/11/2024</strong><br/>
Fixes:<br/>
 - Infrequent crash at iox boot up due to timing<br/>
 - Node status changes caused control conditions to run on plugin nodes. <br/>
 - SMTP mail removing new lines<br/>
<strong>Release notes for: 5.8.4 - 06/27/2024</strong><br/>
Fixes:<br/>
 - Insteon I3 Paddle and I3 Keypad buttons default links<br/>
 - Show Unix Time status values as Timestamps<br/>
 - Faster IoX Backup<br/>
 - Some characters not displayed correctly in Admin Console<br/>
For Developers:<br/>
 - Plugin timestamp support<br/>
 - Allow node servers to define their own status names in nodedefs<br/>
 - Fill in device type field for Zigbee (so Philips hue can be recognized)<br/>
 - Query Zigbee devices after they are added<br/>
 - added <rpnode> to Zigbee nodes<br/>
 - Initial support for posting events to MQTT<br/>
 - Fix ISO8601 Timestamps for node property history and events<br/>
<strong>Release notes for: 5.8.3_2 - 05/23/2024</strong><br/>
Fixes:<br/>
 - Added <> to message ID in SMTP mailer
 - Added uuid to SMTP mailer
 - SMTP large body was not sent
Enhancements:<br/>
 - Events are now published through mqtt as well
 - Removed dependency on Status names
 - SNI automatically enabled for OpenADR
<strong>Release notes for: 5.8.3_0 - 04/22/2024</strong><br/>
Fixes:<br/>
 - Remove default time events from event viewer<br/>
Features:<br/>
 - Better support for enhanced hue (for Phillips Hue)<br/>
 - Support Zigbee Color XY / Temperature<br/>
 - Allow user to manually specify Zigbee radio channel (for Securifi devices)<br/>
<strong>Release notes for: 5.8.0_1 - 01/03/2024</strong><br/>
- Fixed reboot on polisy when using ZMatter in original mode<br/>
<strong>Release notes for: 5.8.0 - 01/01/2024</strong><br/>
- Fixed system crash (for Insteon users)<br/>
- Fixed subscription causing crash when bombarded <br/>
- Misc bug fixes<br/>
- Integration of sqlite database for recording events/property changes<br/>
- Node property history database - disabled by default<br/>
<strong>Release notes for: 5.7.1_07 - 12/01/2023</strong><br/>
- Fix for subscription hang
- Fix for 4.9 migration crash
<strong>Release notes for: 5.7.1_05 - 11/29/2023</strong><br/>
- Crash while initializing PLM (older versions)<br/>
<strong>Release notes for: 5.7.1_03 - 11/27/2023</strong><br/>
- Zooz dongle issue<br/>
- Initial db<br/>
<strong>Release notes for: 5.7.1_02 - 11/15/2023</strong><br/>
<strong>Fixes</strong><br/>
- Crash during restart<br/>
- Crash during usubscribe<br/>
- Z-Wave change from bridge to static  <br/>
<strong>Release notes for: 5.7.1_01 - 11/09/2023</strong><br/>
- Thermostat min/max validation incorrect for some Z-Wave thermostats<br/>
- S2 Verification popup appears when using SmartStart<br/>
- Graceful hadling of HomeAssistant bombardment through websockets<br/>
- Subscriptions filling up due to HomeAssistant not closing sockets</br>
- Right mouse click support for FreeBSD <br/>
<strong>Enhancements</strong><br/>
- Support ISY994 version 4.9 migration<br/>
- Add auto/on/off configuration setting for enabling Z-Wave and Zigbee<br/>
- New installations default to using ZMatter Z-Wave<br/>
<strong>APIs</strong><br/>
- Add event indicating all nodes for a device have been added<br/>
- Add 'hint' field to all nodes<br/>
<strong>Release notes for: 5.7.0_4 - 10/09/2023</strong><br/>
- Possible fix for all programs being disabled after upgrade<br/>
- I3 Paddle/Keypad not showing up correctly in ISY Scenes<br/>
- Programs disabled after upgrading<br/>
- Z-Wave region default setting may be incorrect<br/>
- Max subscription error debugging support<br/>
<strong>Release notes for: 5.7.0 - 09/08/2023</strong><br/>
- Crit not being initialized causing zero size files and other anomalies<br/>
- Fix: Zigbee color commands not available for some customers using Sengled color bulbs<br/>
- Fix: Zigbee devices unexpectedly removed from network<br/>
<br/>
Zigbee:<br/>
- Support for Zigbee On/Off switch<br/>
- Support for Zigbee occupancy cluster<br/>
- Basic support for Zigbee door locks (lock/unlock/query)<br/>
<br/>
Z-Wave:<br/>
- Support .gbl OTA Firmware upgrade files<br/>
- Support abandon OTA Firmware upgrade<br/>
INSTEON:<br/>
- Support dimmer/relay mode for I3 Paddle and I3 Keypad<br/>
- Support various flags for I3 Paddle and I3 Keypad<br/>
<br/>
General:<br/>
- Support dynamic text status values for node servers<br/>
- Add parameter initial values for light on/off commands<br/>
<hr/>
<strong>Release notes for: 5.6.5_1 - 08/31/2023</strong><br/>
OpenADR Dashboard cannot find icons <br/>
Crit not being initialized<br/>
Support for upgrading the OS to 13.2<br/>
<hr/>
<strong>Release notes for: 5.6.4_7 - 08/23/2023</strong><br/>
Fixed socket/file description exhaustion issue<br/>
<hr/>
<strong>Release notes for: 5.6.4 - 08/11/2023</strong><br/>
<br/>
Z-Wave devices no longer responding when IoX restarts<br/>
Faster port detection for Z-Wave<br/>
Z-Wave backups no longer progressively get larger<br/>
Native linking of Insteon I3 Outlet nodes<br/>
Bootup crash when too much network traffic <br/>
Log showing IPV6 addresses only<br/>
File system status showing garbage<br/>
Insteon I3 KPL support<br/>
Z-Wave OTA Firmware updates (limited to intel hex format)<br/>
Zigbee sensor support<br/>
Increased max nodes from 1024 to 2048<br/>
Simplified pg3 authorization.<br/>
Webserver enhancements.<br/>
OpenADR Dashboard is now incorporated into the Admin Console.<br/>
************ libwebsockets ************
libwebsockets-4.3.3
Version        : 4.3.3
Installed on   : Fri Feb 14 17:17:04 2025 EST
Origin         : net/libwebsockets
Prefix         : /usr/local
Categories     : net devel
Licenses       : MIT
Maintainer     : ports@FreeBSD.org
WWW            : https://libwebsockets.org/
Comment        : C library for lightweight websocket clients and servers
Options        :
	GLIB           : off
	HTTP2          : on
	HTTP_PROXY     : off
	LIBEV          : off
	LIBEVENT       : off
	LIBUV          : on
	MBEDTLS        : off
	MQTT           : on
	OPENSSL        : on
	PEERLIMITS     : off
	PLUGINS        : off
	SECURE_STREAMS : off
	SOCKS          : off
	SQLITE         : off
	WEBSERVER      : off
	libuv.so.1
Shared Libs provided:
	libwebsockets.so.19
	libwebsockets-evlib_uv.so
Annotations    :
	repo_type      : binary
	repository     : udi
Flat size      : 1.95MiB
Description    :
Libwebsockets is a lightweight pure C library built to use minimal CPU and
memory resources, and provide fast throughput in both directions as client
or server.
************ tpm2-tools ************
tpm2-tools-5.6_1
Version        : 5.6_1
Installed on   : Fri Feb 14 17:16:11 2025 EST
Origin         : security/tpm2-tools
Prefix         : /usr/local
Categories     : security
Licenses       : BSD2CLAUSE
Maintainer     : tstruk@gmail.com
WWW            : https://github.com/tpm2-software/tpm2-tools
Comment        : TPM2 tools
	libtss2-tctildr.so.0
	libtss2-sys.so.1
	libtss2-rc.so.0
	libtss2-mu.so.0
	libtss2-fapi.so.1
	libtss2-esys.so.0
	libcurl.so.4
Annotations    :
	build_timestamp: 2025-01-09T19:39:08+0000
	built_by       : poudriere-git-3.4.2
	port_checkout_unclean: no
	port_git_hash  : a40e262549
	ports_top_checkout_unclean: no
	ports_top_git_hash: 2414cbd02b
	repo_type      : binary
	repository     : FreeBSD-udx
Flat size      : 1.36MiB
Description    :
This port contains the code for the TPM (Trusted Platform Module) 2.0 tools
based on tpm2-tss.
************ mosquitto ************
mosquitto-2.0.18
Version        : 2.0.18
Installed on   : Fri Feb 14 17:17:06 2025 EST
Origin         : net/mosquitto
Prefix         : /usr/local
Categories     : net
Licenses       : EPL
Maintainer     : joe@thrallingpenguin.com
WWW            : https://mosquitto.org/
Comment        : Open source MQTT broker
Options        :
	CARES          : on
	WEBSOCKETS     : on
	libwebsockets.so.19
	libcjson.so.1
	libcares.so.2
	libmosquittopp.so.1
	libmosquitto.so.1
Annotations    :
	cpe            : cpe:2.3:a:eclipse:mosquitto:2.0.18:::::freebsd14:x64
	repo_type      : binary
	repository     : udi
Flat size      : 1003KiB
Description    :
Mosquitto is an open source (BSD licensed) message broker that implements
the MQ Telemetry Transport protocol versions 3.1 and 3.1.1. MQTT provides
a lightweight method of carrying out messaging using a publish/subscribe
model. This makes it suitable for "machine to machine" messaging such as
with low power sensors or mobile devices such as phones, embedded
computers or microcontrollers like the Arduino.
************ pg3x ************
pg3x-3.3.19
Version        : 3.3.19
Installed on   : Thu Jun 19 16:08:10 2025 EDT
Origin         : misc/pg3x
Prefix         : /usr/local
Categories     : misc
Licenses       : MIT
Maintainer     : benoit@universal-devices.com
WWW            : https://github.com/UniversalDevicesInc/pg3
Comment        : Polyglot PG3x for UDI eisy
	libthr.so.3
	libssl.so.30
	libm.so.5
	libgcc_s.so.1
	libcxxrt.so.1
	libcrypto.so.30
	libc.so.7
	libc++.so.1
Annotations    :
	repo_type      : binary
	repository     : udi
Flat size      : 67.2MiB
Description    :
PG3x Plugins manager for Universal Devices eisy/Polisy
Release nodes for 3.3.19 - 06/04/2025
- Auto-Logout timeout increased
- After uploading profiles, trigger a profile reindex on IoX
- Developer page: Add new buttons at the top
Release notes for 3.3.18 - 01/27/2025
- Added enhanced webhook support (Required for Tesla plugin)
Release notes for 3.3.17 - 12/10/2024
- Fix migration process (restore backup from another unit)
Release notes for 3.3.16 - 11/26/2024
- Fix to Developer plugin edit
Release notes for 3.3.15 - 11/20/2024
- Add support for upcoming eisy-ui
- Fix plugin updates when using git
Release notes for 3.3.13 - 10/16/2024
- PG3 is now available using /plugins/ route
- Fixed /auth when serving from port 443
- Fixed portalAuth when account is using special characters
- Minor bug fixes
- New service files for PG3 and plugins
- Security: remove token fron getNsInfo messages to plugins
- Security: Submitting new plugins require a developer token
- Node names are sanitized: /<> are replaced
- Display the plugin edition in the details page
- Log API requests to PG3
- Release for FreeBSD 14
FreeBSD 13: PG3x last release is 3.2.27
FreeBSD 14: PG3x 3.3.0+
*** Networking Information ***
re0: flags=1008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500
	options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
	ether 00:21:b9:02:5f:80
	inet <IP> netmask HGidden broadcast IP
	inet6 fe80::3802:f222:9f4e:2522%re0 prefixlen 64 scopeid 0x1
	media: Ethernet autoselect (100baseTX <full-duplex>)
	status: active
	nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
lo0: flags=1008049<UP,LOOPBACK,RUNNING,MULTICAST,LOWER_UP> metric 0 mtu 16384
	options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
	inet 127.0.0.1 netmask 0xff000000
	inet6 ::1 prefixlen 128
	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
	groups: lo
	nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
*** USB Devices ***
ugen0.1: <Intel XHCI root HUB> at usbus0, cfg=0 md=HOST spd=SUPER (5.0Gbps) pwr=SAVE (0mA)
ugen0.2: <CP2105 Dual UART Bridge Silicon Labs> at usbus0, cfg=0 md=HOST spd=FULL (12Mbps) pwr=ON (100mA)
ugen0.3: <PL2303 Serial Port / Mobile Phone Data Cable Prolific Technology, Inc.> at usbus0, cfg=0 md=HOST spd=FULL (12Mbps) pwr=ON (100mA)
ugen0.4: <AX201 Bluetooth Intel Corp.> at usbus0, cfg=0 md=HOST spd=FULL (12Mbps) pwr=ON (100mA)
*** Upgrade Status ****
UDX_UPGRADE_STATUS="inactive"
Edited by TheA2Z
Solved by Techman
The firmware versions you're showing are not the latest versions, once you get the access issue cleared up you should update your packages again as it's possible your update didn't complete.
Are you on a Mac or a PC?
If you're using a VPN disable it.
Clear your Java cache again, be sure to check all 3 boxes, then download the IoX Launcher from here:
https://isy.universal-devices.com/start.jnlp
Also remove power from the eisy for 30 seconds and then allow it to reboot
Thanks @Techman
Its fixed.
Im on PC.
I did the java, and new IoX Launcher again but what i think fixed it was I went through all my backround tasks.  I ended the vpn even though it was not on as well as other background tasks.  Started working.  😀
