Scene strangness - works via alexa or admin console
Have a scene acting up.  Replaced 2 switchlinc using the replace routine in the ISY-994
Neither switch show in the links table for the keypad that controls the scene (A on an 8 button)
Verbally via Alexa or on the admin console the A button lights and the switchlincs turn on the lights.
If I press the A button, nothing happens besides the A button toggles, no lights respond.
restored A no change
Both switches claim to be part of the scene when I try to re-add them to the scene but don't show in the links table, maybe scenes don't.
Thoughts on fixing it and why it is behaving how it is?
Thank you
I have never used the replace routine in the ISY.  I find it better to delete the dead or removed device before actually removing it if it is still communicating and then adding the new one.  Yes in a large system with a lot of programs it is a hassle.  I also found rebooting before adding the new ones improved reliability if I used the same names for the device.  Now I am changing the name just to be sure anyway.  Dining was replaced with a new i3 so it is now Dining i3.
The next step is to run through all the programs and look for the green // areas where the device isn't found and replace them with the new device or updated scene.
