Posted July 20Jul 20 I just bought and am trying to set up the "new" Elk-7TS touchscreen keypad. I would like to try to get it so that I could check the status of a few lights or devices and potentially turn them on and off. I have tried creating some "lights" inside of the ElkRP2 and I can see these on the touchscreen, which is great, but none of them do anything. they need configuration. I believe that these should somehow make nodes in my Polisy but I haven't been able to figure out how to do so. I tried setting the nodeserver to "ELKID" and putting some "ELKID=4" in notes for devices but that didn't work either. any suggestions?
July 20Jul 20 Did you follow all the instructions in the plugin configuration page? https://github.com/UniversalDevicesInc-PG3/udi-poly-ELK/blob/master/configdoc.md ELKID This works by right-clicking on a node in the ISY and adding a note with "ELKID=n" where n is a unique integer Then click on the "export" link provided below which will appear once your ELK is synced Note: Depending on how many devices on your IoX it may take a while to process and generate the export file. Once the file is downloaded, open ElkRP connect to your System, then right click on Automation -> Lighting and import the file.
August 9Aug 9 Author @Jimbo.Automates: I got my lights imported to my Elk system and there is good news and bad news: now, when I try to turn the lights on or off with the M1, it works! and it is instantaneous! but, when I turn the lights on with any other means, the M1 doesn't know that the lights are on. here are a few other comments I have that could help others get through this process. 1) there is an "export" button in the Elk Nodeserver in the Admin Console. it is confusing because that is not the "export" that is used to export the data from the ISY (to later import into ElkRP2. 2) when using the "ELKID" method there cannot be anything else in the "notes" than the ELKID=x. also there cannot be anything in the "location" which is right above the "notes" in the admin console. 3) Scenes don't work using this ELKID method, which is unfortunate but not surprising. 4) In ElkRP2, the "import" that is necessary is found in the "lighting" area by right clicking it and then selecting "import lighting data".
August 16Aug 16 Author @Jimbo.AutomatesI appreciate your help with this great nodeserver. I am having one snag: even though I can control my lights with the Elk keypad, the keypad and the elk system aren't getting updated on what the status of the lights is when I change the lights using any other method than the Elk system itself. how can I address that?
