SHM Posted Thursday at 11:34 PM Posted Thursday at 11:34 PM Got my new EISY a few weeks ago. Everything transferred OK, but I noticed in UD mobile that the ratgdo door state for the plugin has a label of either "0" or "1" instead on"closed" or "open." B Mercier thought it might be a plugin issue. I have been using the ratgdo plugin flawlessly, on a Liftmaster 5.0, Security 2.0 commercial door opener, using the ESPHome firmware for "dry contact." In an effort to fix the UDM issue, I did an OTA firmware upgrade to the ratgdo, again using 2.53/security 2.o/dry contact firmware. Now, there is no response to the open/close command on the ratgdo, (when triggered from the device on chrome, UDM or the AC). Attached is screenshot of the ratgdo device information. The IP of the ratgdo is 10.0.0.21 and the EISY is 10.0.170 Quote
Goose66 Posted yesterday at 02:18 AM Posted yesterday at 02:18 AM The original issue just sounds like the “profile” for the plugin didn’t get successfully loaded. You could have loaded the profile from the PG3 dashboard and restarted the Admin Console to see if that straightened it out. However, now it sounds like the plugin setup is corrupt once you updated your ratgdo. I would suggest factory reset ratgdo, delete plugin, and then follow all the instructions again to install and discover. Quote
SHM Posted 14 hours ago Author Posted 14 hours ago Sounds like a plan. By factory reset, do you mean erase and re-install the ratgdo firmware? Quote
Goose66 Posted 13 hours ago Posted 13 hours ago The erase is not as important as going through the setup steps to get the initial settings right so the Discovery process will work. See here and here. Quote
Join the conversation
