Copy a nodes "advanced" configuration settings
Is there a way to copy the advanced configuration settings in favorites one object node to another, for example, value based color settings on multiple temperature sensors.
On 9/14/2025 at 6:56 AM, Javi said:
Not currently, but the Advanced Configurations will likely require an update soon due to some other changes, so I'll keep this in mind.
Understood..
On a simular  topic,  it's already been noted that iOS and android backups are not compatible, but a way to export/import just favorites would be very convenient for copying "consoles" between device devices (and hopefully easier to implement 😀)
btw:  android should not even be allowed to import an iOS backup, it really fuckers the android app, requiring a purge and then reinstall (and a lesson turned)....
  • 1 month later...
Quite a bit later, but on a related topic I really wish that the UD Mobile favorites config could just be a bunch of XML or similar so I could just edit it with a keyboard.
