Hunter Douglas PRODUCTION v1.13.0
Ok, the re-write and validation of G2 & G3 is complete.  Unfortunately, our sample size in testing is one of each system ; but here we go!
The feature set is short but the code clean-up and resiliency should make up for it.
polling 60 shortPoll, 600 longPoll (should roll out as default)
  • 60 shortPoll is how often G2 will poll the gateway (same as before but was longPoll) to update (you can try shorter but you may flood the G2 gateway, YMMV)
  • shortPoll also flips the ST cmd for heartbeat, re-starts the G3 client if it fails
  • 600 longPoll is how often G3 will poll the gateway.  Has been moved out to 10min as this is really just belt/suspenders for G3.  Almost not needed as I have found the sse client is more than able to keep G3 updates accurate.
  • longPoll does nothing for G2
controller
  • ST cmd still tracks heartbeat, easy to monitor in a program
  • ST status is tracking connected/disconnected, basically if the plugin is running
  • number of nodes has been added and can be used as a check for how many shades + scenes you have discovered.
  • G3 , complete re-write of the sse event client which is much much more resilient and less resources
shades
  • complete rewrite, should just work
scenes
  • G3 activation is now calculated.  MUCH quicker and more accurate.  Works even when the mobile app is blank.
  • also a complete re-write
Take a look at the code if you are interested on GITHUB  .  I welcome feedback & obviously value bug reports.
NOTE!!! - there are a number of profile changes, if you are writing overtop of a current node, you will likely need to hit the load profile button and re-load eisy-ui or the AC.
VERSION = '1.13.0'
1.13.0
DONE polling rewrite, controller: shortPoll=G2 poll, heartbeat for all, re-start G3 events, longPoll=G3 poll
DONE polling rewrite, shade: shortPoll: re-start events if stopped, longPoll: not-used
DONE polling rewrite, scene: shortPoll: re-start events if stopped, manually clear G2 scene activate, longPoll: not-used
NOTE default & recommend setting shortPoll=60, longPoll=600
DONE major re-write of function and Event routines
DONE add number of nodes managed by controller to controller node
Edited by sjenkins
