v3.1.22 in beta ; generic/dimmer features
Keeping with adding as much to the beta before pushing to production.   Want to balance those who are looking for stability versus feature growth.
This beta came from some requests to build the generic/dimmer device a bit.
What we've added recently to generic/dimmer
  1. Scene triggering
  2. Dynamic persistence of onlevel (returns to last onlevel)
  3. Visability of onlevel
  4. NEW: Ability to switch between static or dynamic onlevel.  Static is consistent to Insteon switches, basically Don will always return to the set onlevel.  DFON goes to 100%, again like Insteon
  5. below are the rest of the changes from current production, mostly modernization or back-office changes
3.1.22
DONE generic/dimmer static/dynamic behaviour
3.1.21
DONE generic/dimmer to model dimmer ST & OL
DONE name & address check using poly interface
DONE consistent use of poly versus polyglot
DONE fix nagging error check in main()
DONE controller discover refactor
DONE add notice for ISY authorized error (was only in logs)
3.1.20
DONE fix controller ST "status" on at start, off at stop / delete, "control" still heartbeat
DONE garage send CMDs, motor, motion, obstruction ; get naming consistent
DONE standardize startup sequence
DONE rewrite checkParams, Discovery
DONE add NumberOfNodes
DONE switch/generic/dimmer/temp(R/C): nodes use polyglot persistence, delete old db files
DONE swtich cmd TOGGLE add
DONE consolidate temp, tempC, tempRC into one module
DONE temp variable writing now with shortPoll (only upon change, considers precision)
DONE refactor function naming
DONE refactor garage, fix persistence, sse client
DONE backfeed garage improvements to switch(done), generic(done), temperature()
3.1.15
DONE generic, dimmer, change ST to OL, memory of level for DON, DFON/DFOF, command
