October 22Oct 22 54 minutes ago, bpwwer said:version 2.0.13 has the additional info in the log messageI have the log set to Info and that's where it stops. I tried updating but it still shows 2.0.12 and nothing changed. The PG3 log just says..2025-10-21 18:11:13.669 [pg3] info: startNs:: Roomba 2025-10-21 18:11:13.669 [pg3] info: startNs:: Roomba is valid 2025-10-21 18:11:13.973 [pg3] info: checkLicense:: Roomba Valid perpetual license found. 2025-10-21 18:11:13.978 [pg3] info: startNs:: Roomba finished update check 2025-10-21 18:11:13.978 [pg3] info: startNs:: Starting Roomba 2025-10-21 18:11:13.979 [pg3] info: call_udx: Making request to socket with url /rest/pg3.start.ns 2025-10-21 18:11:13.986 [pg3] info: Received commands on topic udi/pg3/frontend/system/lore: getStoreEntry 2025-10-21 18:11:13.990 [pg3] info: Getting Node Server store entry for nsid 4e9ec7a1-1d79-4a17-9c66-172df4733ed5 from store Beta 2025-10-21 18:11:14.008 [pg3] info: API call: GET /logs/main 2025-10-21 18:11:14.964 [pg3] info: Received commands on topic udi/pg3/connections/ns/00:21:b9:02:6d:fb_3: connected2025-10-21 18:11:14.968 [pg3] info: Nodeserver connection status 00:21:b9:02:6d:fb profileNum 3: 12025-10-21 18:11:14.975 [pg3] info: Pushing notification {"title":"Roomba (3): Connected","body":"from PG3 (00:21:b9:02:6d:fb)"} to UD Mobile2025-10-21 18:11:15.006 [pg3] info: Received commands on topic udi/pg3/ns/system/00:21:b9:02:6d:fb_3: installprofile2025-10-21 18:11:15.011 [pg3] info: installProfile: Roomba :: read /var/polyglot/pg3/ns/0021b9026dfb_3/profile/nodedef2025-10-21 18:11:15.011 [pg3] info: Uploading nodedefs.xml2025-10-21 18:11:15.011 [pg3] info: installProfile: Roomba :: read /var/polyglot/pg3/ns/0021b9026dfb_3/profile/editor2025-10-21 18:11:15.012 [pg3] info: Uploading editors.xml2025-10-21 18:11:15.012 [pg3] info: installProfile: Roomba :: read /var/polyglot/pg3/ns/0021b9026dfb_3/profile/nls2025-10-21 18:11:15.012 [pg3] info: Uploading en_us.txt2025-10-21 18:11:15.015 [pg3] info: Received commands on topic udi/pg3/ns/custom/00:21:b9:02:6d:fb_3: set2025-10-21 18:11:15.025 [pg3] info: Received commands on topic udi/pg3/ns/system/00:21:b9:02:6d:fb_3: config2025-10-21 18:11:15.027 [pg3] info: IoX Request: [Try: 1] [00:21:b9:02:6d:fb] :: - http://127.0.0.1/rest/ns/profile/3/upload/nodedef/nodedefs.xml2025-10-21 18:11:15.033 [pg3] info: IoX Response: [Try: 1] [00:21:b9:02:6d:fb] :: [200] :: 5.602453ms - http://127.0.0.1/rest/ns/profile/3/upload/nodedef/nodedefs.xml2025-10-21 18:11:15.035 [pg3] info: Received commands on topic udi/pg3/ns/custom/00:21:b9:02:6d:fb_3: getAll2025-10-21 18:11:15.037 [pg3] info: ProfileUpload: upload of nodedefs.xml for slot 3 successful.2025-10-21 18:11:15.045 [pg3] info: Received commands on topic udi/pg3/ns/system/00:21:b9:02:6d:fb_3: getNsInfo2025-10-21 18:11:15.070 [pg3] info: IoX Request: [Try: 1] [00:21:b9:02:6d:fb] :: - http://127.0.0.1/rest/ns/profile/3/upload/editor/editors.xml2025-10-21 18:11:15.071 [pg3] info: IoX Response: [Try: 1] [00:21:b9:02:6d:fb] :: [200] :: 1.377593ms - http://127.0.0.1/rest/ns/profile/3/upload/editor/editors.xml2025-10-21 18:11:15.075 [pg3] info: ProfileUpload: upload of editors.xml for slot 3 successful.2025-10-21 18:11:15.124 [pg3] info: IoX Request: [Try: 1] [00:21:b9:02:6d:fb] :: - http://127.0.0.1/rest/ns/profile/3/upload/nls/en_us.txt2025-10-21 18:11:15.125 [pg3] info: IoX Response: [Try: 1] [00:21:b9:02:6d:fb] :: [200] :: 1.356419ms - http://127.0.0.1/rest/ns/profile/3/upload/nls/en_us.txt2025-10-21 18:11:15.128 [pg3] info: ProfileUpload: upload of en_us.txt for slot 3 successful.2025-10-21 18:11:15.129 [pg3] info: Tell IoX to reload the profile in slot 32025-10-21 18:11:15.173 [pg3] info: IoX Request: [Try: 1] [00:21:b9:02:6d:fb] :: - http://127.0.0.1/rest/ns/3/profile/reload2025-10-21 18:11:15.216 [pg3] info: Received commands on topic udi/pg3/ns/custom/00:21:b9:02:6d:fb_3: set2025-10-21 18:11:16.023 [pg3] info: IoX Response: [Try: 1] [00:21:b9:02:6d:fb] :: [200] :: 850.490645ms - http://127.0.0.1/rest/ns/3/profile/reload2025-10-21 18:11:19.928 [pg3] info: Received commands on topic udi/pg3/ns/custom/00:21:b9:02:6d:fb_3: set
October 23Oct 23 Looks like I forgot to push the changes from my local copy. I just did that so it should update to 2.0.13 now.Set the log level to debug and then download the log an either attach or PM it to me.
October 23Oct 23 Updated to 2.0.13. Hope this is helpful...2025-10-22 21:00:05.756 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2025-10-22 21:00:05.756 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2025-10-22 21:00:05.757 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2025-10-22 21:00:10.761 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2025-10-22 21:00:10.761 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2025-10-22 21:00:10.761 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2025-10-22 21:00:15.767 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2025-10-22 21:00:15.767 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2025-10-22 21:00:15.767 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2025-10-22 21:00:20.771 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2025-10-22 21:00:20.771 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2025-10-22 21:00:20.771 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2025-10-22 21:00:25.058 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message stop2025-10-22 21:00:25.058 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING stop2025-10-22 21:00:25.059 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS stop message {} from Polyglot2025-10-22 21:00:25.059 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down.2025-10-22 21:00:25.059 Command udi_interface.interface INFO interface:stop: Disconnecting from MQTT... localhost:88832025-10-22 21:00:25.059 Command udi_interface.interface INFO interface:_disconnect: MQTT Unexpected disconnection. Reason code: Normal disconnection. Sent by server: False. Retry in 10 seconds.2025-10-22 21:00:29.518 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=302025-10-22 21:00:29.519 MainThread udi_interface INFO init:<module>: UDI interface initializing2025-10-22 21:00:29.519 MainThread udi_interface INFO init:<module>: User=None2025-10-22 21:00:29.519 MainThread udi_interface INFO init:<module>: Home=/var/polyglot/pg3/ns/0021b9026dfb_32025-10-22 21:00:29.519 MainThread udi_interface INFO init:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b9026dfb_32025-10-22 21:00:29.519 MainThread udi_interface INFO init:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NmQ6ZmIiLCJwcm9maWxlTnVtIjozLCJsb2dMZXZlbCI6IkRFQlVHIiwidG9rZW4iOiJjcmlpTFRVdFdpbT1wayZHIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjMuMjIiLCJpc3lWZXJzaW9uIjoiNi4wLjAiLCJlZGl0aW9uIjoiRnJlZSJ92025-10-22 21:00:29.519 MainThread udi_interface INFO init:<module>: Loading interface module2025-10-22 21:00:29.561 MainThread udi_interface INFO interface:<module>: Loading MQTT module2025-10-22 21:00:30.053 MainThread udi_interface INFO interface:<module>: MQTT module loaded2025-10-22 21:00:30.270 MainThread udi_interface INFO init:<module>: Loading udi_interface module2025-10-22 21:00:30.271 MainThread udi_interface INFO init:<module>: Loading node module2025-10-22 21:00:30.271 MainThread udi_interface INFO init:<module>: Loading custom module2025-10-22 21:00:30.271 MainThread udi_interface INFO init:<module>: Loading isy module2025-10-22 21:00:30.271 MainThread udi_interface INFO init:<module>: Loading OAuth module2025-10-22 21:00:30.271 MainThread udi_interface INFO init:<module>: UDI interface initialized2025-10-22 21:00:30.271 MainThread udi_interface INFO init:<module>: UDI Python Interface for Polyglot version 3 3.3.18 Starting...2025-10-22 21:00:30.277 MainThread udi_interface DEBUG udi_interface:write: CV or numpy module not found, falling back to PIL2025-10-22 21:00:30.277 MainThread udi_interface DEBUG udi_interface:write: PIL module not found, maps are disabled2025-10-22 21:00:30.278 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.3.22 [ISY: 6.0.0, Slot: 3]2025-10-22 21:00:30.279 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.1.220', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'}2025-10-22 21:00:30.279 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:88832025-10-22 21:00:30.279 MainThread udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot.2025-10-22 21:00:30.279 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b9026dfb_3.cert key: 0021b9026dfb_3.key ca: /usr/local/etc/ssl/certs/ud.ca.cert2025-10-22 21:00:30.286 Thread-1 udi_interface INFO roomba-poly:start: Roomba node server starting2025-10-22 21:00:30.287 Interface udi_interface.interface INFO interface:_startMqtt: MQTT keepalive is 300 seconds.2025-10-22 21:00:30.339 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success2025-10-22 21:00:30.340 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:6d:fb_3 - MID: 2 Result: 02025-10-22 21:00:30.386 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 2. Reason codes: ['Granted QoS 0']2025-10-22 21:00:30.468 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparamsdoc2025-10-22 21:00:30.469 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getAll2025-10-22 21:00:30.469 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getAll2025-10-22 21:00:30.470 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'eda8258d-4049-4939-80ac-055ecba1ef6e', 'uuid': '00:21:b9:02:6d:fb', 'profileNum': 3, 'key': 'customdata', 'value': '{"robots":{"192.168.1.210":{"hostname":"Roomba-3166481071120860","robot_name":"Living Roomba","ip":"192.168.1.210","mac":"D0:C5:D3:0D:07:3C","firmware":"v2.4.17-138","sku":"R985020","blid":"3166481071120860","capabilities":{"pose":1,"ota":2,"multiPass":2,"carpetBoost":1,"pp":1,"binFullDetect":1,"langOta":1,"maps":1,"edge":1,"eco":1,"svcConf":1}},"192.168.1.211":{"hostname":"Roomba-3164421081537810","robot_name":"Upstairs Roomba","ip":"192.168.1.211","mac":"80:C5:F2:C6:7D:78","firmware":"v2.4.17-138","sku":"R985020","blid":"3164421081537810","capabilities":{"pose":1,"ota":2,"multiPass":2,"carpetBoost":1,"pp":1,"binFullDetect":1,"langOta":1,"maps":1,"edge":1,"eco":1,"svcConf":1}},"192.168.1.212":{"hostname":"Roomba-80B2841452328550","robot_name":"Entry Roomba","ip":"192.168.1.212","mac":"70:66:55:42:E6:BA","firmware":"v2.4.17-138","sku":"R981020","blid":"80B2841452328550","capabilities":{"pose":1,"ota":2,"multiPass":2,"carpetBoost":1,"pp":1,"binFullDetect":1,"langOta":1,"maps":1,"edge":1,"eco":1,"svcConf":1}}}}', 'dbVersion': 1} from Polyglot2025-10-22 21:00:30.470 Thread-3 (handleRobotData) udi_interface INFO roomba-poly:handleRobotData: Loading saved robots {'robots': {'192.168.1.210': {'hostname': 'Roomba-3166481071120860', 'robot_name': 'Living Roomba', 'ip': '192.168.1.210', 'mac': 'D0:C5:D3:0D:07:3C', 'firmware': 'v2.4.17-138', 'sku': 'R985020', 'blid': '3166481071120860', 'capabilities': {'pose': 1, 'ota': 2, 'multiPass': 2, 'carpetBoost': 1, 'pp': 1, 'binFullDetect': 1, 'langOta': 1, 'maps': 1, 'edge': 1, 'eco': 1, 'svcConf': 1}}, '192.168.1.211': {'hostname': 'Roomba-3164421081537810', 'robot_name': 'Upstairs Roomba', 'ip': '192.168.1.211', 'mac': '80:C5:F2:C6:7D:78', 'firmware': 'v2.4.17-138', 'sku': 'R985020', 'blid': '3164421081537810', 'capabilities': {'pose': 1, 'ota': 2, 'multiPass': 2, 'carpetBoost': 1, 'pp': 1, 'binFullDetect': 1, 'langOta': 1, 'maps': 1, 'edge': 1, 'eco': 1, 'svcConf': 1}}, '192.168.1.212': {'hostname': 'Roomba-80B2841452328550', 'robot_name': 'Entry Roomba', 'ip': '192.168.1.212', 'mac': '70:66:55:42:E6:BA', 'firmware': 'v2.4.17-138', 'sku': 'R981020', 'blid': '80B2841452328550', 'capabilities': {'pose': 1, 'ota': 2, 'multiPass': 2, 'carpetBoost': 1, 'pp': 1, 'binFullDetect': 1, 'langOta': 1, 'maps': 1, 'edge': 1, 'eco': 1, 'svcConf': 1}}}}2025-10-22 21:00:30.470 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '5a6a9110-61e4-4c33-a203-b18d05790cf4', 'uuid': '00:21:b9:02:6d:fb', 'profileNum': 3, 'key': 'customparamsdoc', 'value': '<h3>Roomba robots are auto discovered</h3>\n\n<p>If no robots are configured when starting, the node server will start the discovery process.\nThis will look for Roomba devices on the network. For each device found, you will then have\nto manually put the Roomba in to a mode that allows the node server to query the authentication\ninformation from the device. You will be prompted via a notice when this is required.</p>\n\n<p>The discovered Roomba deivces are then saved so that future starts can skip the discovery process.</p>\n\n<p>If you need to re-discover devices, use the "Discover" button in the UI to start the discovery\nprocess. This will clear any exising devices and start from an empty list.</p>\n', 'dbVersion': 1} from Polyglot2025-10-22 21:00:30.470 Thread-3 (handleRobotData) udi_interface.custom DEBUG custom:load: CUSTOM: load {'robots': {'192.168.1.210': {'hostname': 'Roomba-3166481071120860', 'robot_name': 'Living Roomba', 'ip': '192.168.1.210', 'mac': 'D0:C5:D3:0D:07:3C', 'firmware': 'v2.4.17-138', 'sku': 'R985020', 'blid': '3166481071120860', 'capabilities': {'pose': 1, 'ota': 2, 'multiPass': 2, 'carpetBoost': 1, 'pp': 1, 'binFullDetect': 1, 'langOta': 1, 'maps': 1, 'edge': 1, 'eco': 1, 'svcConf': 1}}, '192.168.1.211': {'hostname': 'Roomba-3164421081537810', 'robot_name': 'Upstairs Roomba', 'ip': '192.168.1.211', 'mac': '80:C5:F2:C6:7D:78', 'firmware': 'v2.4.17-138', 'sku': 'R985020', 'blid': '3164421081537810', 'capabilities': {'pose': 1, 'ota': 2, 'multiPass': 2, 'carpetBoost': 1, 'pp': 1, 'binFullDetect': 1, 'langOta': 1, 'maps': 1, 'edge': 1, 'eco': 1, 'svcConf': 1}}, '192.168.1.212': {'hostname': 'Roomba-80B2841452328550', 'robot_name': 'Entry Roomba', 'ip': '192.168.1.212', 'mac': '70:66:55:42:E6:BA', 'firmware': 'v2.4.17-138', 'sku': 'R981020', 'blid': '80B2841452328550', 'capabilities': {'pose': 1, 'ota': 2, 'multiPass': 2, 'carpetBoost': 1, 'pp': 1, 'binFullDetect': 1, 'langOta': 1, 'maps': 1, 'edge': 1, 'eco': 1, 'svcConf': 1}}}}2025-10-22 21:00:30.470 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'b36620bb-4f1e-4bb4-8332-240d19b40c09', 'uuid': '00:21:b9:02:6d:fb', 'profileNum': 3, 'key': 'notices', 'value': '{"setup":"Initializing connection to Living Roomba"}', 'dbVersion': 1} from Polyglot2025-10-22 21:00:30.471 Thread-3 (handleRobotData) udi_interface.custom DEBUG custom:load: CUSTOM: -- checking robots / {'192.168.1.210': {'hostname': 'Roomba-3166481071120860', 'robot_name': 'Living Roomba', 'ip': '192.168.1.210', 'mac': 'D0:C5:D3:0D:07:3C', 'firmware': 'v2.4.17-138', 'sku': 'R985020', 'blid': '3166481071120860', 'capabilities': {'pose': 1, 'ota': 2, 'multiPass': 2, 'carpetBoost': 1, 'pp': 1, 'binFullDetect': 1, 'langOta': 1, 'maps': 1, 'edge': 1, 'eco': 1, 'svcConf': 1}}, '192.168.1.211': {'hostname': 'Roomba-3164421081537810', 'robot_name': 'Upstairs Roomba', 'ip': '192.168.1.211', 'mac': '80:C5:F2:C6:7D:78', 'firmware': 'v2.4.17-138', 'sku': 'R985020', 'blid': '3164421081537810', 'capabilities': {'pose': 1, 'ota': 2, 'multiPass': 2, 'carpetBoost': 1, 'pp': 1, 'binFullDetect': 1, 'langOta': 1, 'maps': 1, 'edge': 1, 'eco': 1, 'svcConf': 1}}, '192.168.1.212': {'hostname': 'Roomba-80B2841452328550', 'robot_name': 'Entry Roomba', 'ip': '192.168.1.212', 'mac': '70:66:55:42:E6:BA', 'firmware': 'v2.4.17-138', 'sku': 'R981020', 'blid': '80B2841452328550', 'capabilities': {'pose': 1, 'ota': 2, 'multiPass': 2, 'carpetBoost': 1, 'pp': 1, 'binFullDetect': 1, 'langOta': 1, 'maps': 1, 'edge': 1, 'eco': 1, 'svcConf': 1}}}2025-10-22 21:00:30.471 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getNsInfo2025-10-22 21:00:30.471 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {'setup': 'Initializing connection to Living Roomba'}2025-10-22 21:00:30.471 Thread-3 (handleRobotData) udi_interface INFO roomba-poly:handleRobotData: We have restored the saved robot list2025-10-22 21:00:30.471 Command udi_interface.custom DEBUG custom:load: CUSTOM: -- checking setup / Initializing connection to Living Roomba2025-10-22 21:00:30.471 Thread-3 (handleRobotData) udi_interface INFO roomba-poly:handleRobotData: Finished with handleRobotData2025-10-22 21:00:30.472 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'efe4202c-acff-4700-afb0-2279d7f2d647', 'uuid': '00:21:b9:02:6d:fb', 'profileNum': 3, 'key': 'nsdata', 'value': '', 'dbVersion': 1} from Polyglot2025-10-22 21:00:30.472 Command udi_interface.interface DEBUG interface:_handleInput: Key nsdata should be passed to node server.2025-10-22 21:00:30.472 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '3a01d9ee-5f2a-4a20-8b0a-f7db77dee25e', 'uuid': '00:21:b9:02:6d:fb', 'profileNum': 3, 'key': 'oauth', 'value': 'null', 'dbVersion': 1} from Polyglot2025-10-22 21:00:30.472 Command udi_interface.interface DEBUG interface:_handleInput: Key oauth should be passed to node server.2025-10-22 21:00:30.472 Thread-5 (handleConfigDone) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving2025-10-22 21:00:30.473 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getNsInfo2025-10-22 21:00:30.473 Thread-5 (handleConfigDone) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.2025-10-22 21:00:30.473 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '2b1790ca-374d-4803-8b3f-adaaa30d06d7', 'uuid': '00:21:b9:02:6d:fb', 'name': 'Hue', 'nsid': 'b8518958-ab70-4555-9d4f-a2da8df86122', 'expires': 0, 'nickname': None, 'profileNum': 1, 'timeAdded': 1664854237273, 'timeStarted': 1761191698145, 'timeModified': 1761191699203, 'version': '1.0.2', 'branch': 'huev2', 'url': 'https://github.com/exking/udi-hue-pg3.git', 'home': '/var/polyglot/pg3/ns/0021b9026dfb_1', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'hue.py', 'shortPoll': 60, 'longPoll': 600, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Beta', 'option': 'a3f28572-0cdd-43c4-a538-ccddf4de8e20', 'noLicense': 0, 'latestVersion': '1.0.3', 'dbVersion': 1, 'developerMode': 0, 'allowIsyAccess': 0, 'requestId': 0, 'edition': 'Free'} from Polyglot2025-10-22 21:00:30.473 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '2f094b72-0426-4151-9b62-479532b21f0f', 'uuid': '00:21:b9:02:6d:fb', 'name': 'Rachio', 'nsid': '61ba95d3-538e-462c-ab54-570af9d19a64', 'expires': 0, 'nickname': None, 'profileNum': 2, 'timeAdded': 1666487988009, 'timeStarted': 1761191692230, 'timeModified': 1761191693957, 'version': '4.0.4', 'branch': 'v4', 'url': 'https://github.com/UniversalDevicesInc-PG3/udi-rachio-poly', 'home': '/var/polyglot/pg3/ns/0021b9026dfb_2', 'log': 'logs/debug.log', 'logLevel': 'ERROR', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'rachio-poly.py', 'shortPoll': 5, 'longPoll': 60, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': 'eee1e738-00db-47a9-b02c-a11e29fc271e', 'noLicense': 0, 'latestVersion': '4.0.4', 'dbVersion': 1, 'developerMode': 0, 'allowIsyAccess': 0, 'requestId': 0, 'edition': None} from Polyglot2025-10-22 21:00:30.473 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '3b5232e3-f94a-4313-93ba-2af09721db63', 'uuid': '00:21:b9:02:6d:fb', 'name': 'VenstarCT', 'nsid': '639a432c-972f-4b09-a168-0225f01d08a0', 'expires': 0, 'nickname': None, 'profileNum': 5, 'timeAdded': 1672551823431, 'timeStarted': 1761191691529, 'timeModified': 1761191693669, 'version': '3.0.11', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/venstar-pg3-3.0.11.zip', 'home': '/var/polyglot/pg3/ns/0021b9026dfb_5', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'main.py', 'shortPoll': 20, 'longPoll': 150, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '05cc4cc4-406d-46a0-8a80-1582d54d344f', 'noLicense': 0, 'latestVersion': '3.0.11', 'dbVersion': 1, 'developerMode': 0, 'allowIsyAccess': 0, 'requestId': 0, 'edition': None} from Polyglot2025-10-22 21:00:30.473 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4f2c6b93-b9af-4855-adf4-a31914664f82', 'uuid': '00:21:b9:02:6d:fb', 'name': 'VUE', 'nsid': '91c07bd2-79fc-4e1b-9352-220108db94d0', 'expires': 0, 'nickname': None, 'profileNum': 6, 'timeAdded': 1696473593841, 'timeStarted': 1761191691215, 'timeModified': 1761191698867, 'version': '1.0.27', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/udi-emporia-vue-poly.zip', 'home': '/var/polyglot/pg3/ns/0021b9026dfb_6', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'vue.py', 'shortPoll': 10, 'longPoll': 60, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'status_node': '268031', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': 'ed2ccff9-b1e5-4603-a4c8-fe345a6f6566', 'noLicense': 0, 'latestVersion': '1.0.27', 'dbVersion': 1, 'developerMode': 0, 'allowIsyAccess': 0, 'requestId': 0, 'edition': 'Free'} from Polyglot2025-10-22 21:00:30.473 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'a5cc19cc-2f86-4dc4-b2fe-13ee9cdc9da4', 'uuid': '00:21:b9:02:6d:fb', 'name': 'Notification', 'nsid': '132e8dd7-e452-41dd-80f1-6a7da660f00b', 'expires': 0, 'nickname': None, 'profileNum': 7, 'timeAdded': 1697775731020, 'timeStarted': 1761191691344, 'timeModified': 1761191694009, 'version': '3.6.16', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Notification.zip', 'home': '/var/polyglot/pg3/ns/0021b9026dfb_7', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'notification-poly.py', 'shortPoll': 60, 'longPoll': 600, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '74de37ab-1f56-4d97-8da1-041a27581261', 'noLicense': 0, 'latestVersion': '3.6.16', 'dbVersion': 1, 'developerMode': 0, 'allowIsyAccess': 0, 'requestId': 0, 'edition': None} from Polyglot2025-10-22 21:00:30.473 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '5191f17f-41a8-479e-93ff-6912b82a32e9', 'uuid': '00:21:b9:02:6d:fb', 'name': 'Roomba', 'nsid': '4e9ec7a1-1d79-4a17-9c66-172df4733ed5', 'expires': 0, 'nickname': None, 'profileNum': 3, 'timeAdded': 1760930887773, 'timeStarted': 1761192029456, 'timeModified': 1761192030415, 'version': '2.0.13', 'branch': 'master', 'url': 'https://github.com/BME-nodeservers/udi-roomba-poly', 'home': '/var/polyglot/pg3/ns/0021b9026dfb_3', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'roomba-poly.py', 'shortPoll': 5, 'longPoll': 60, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Beta', 'option': '', 'noLicense': 0, 'latestVersion': '2.0.2', 'dbVersion': 1, 'developerMode': 0, 'allowIsyAccess': 0, 'requestId': 0, 'edition': 'Free'} from Polyglot2025-10-22 21:00:30.473 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '3a787e0a-f584-4add-a91a-2b8137472664', 'uuid': '00:21:b9:02:6d:fb', 'name': 'Climacell', 'nsid': 'a2eca832-fb97-4da4-b32e-3edd41db54ed', 'expires': 0, 'nickname': None, 'profileNum': 4, 'timeAdded': 1760977786584, 'timeStarted': 1761191691746, 'timeModified': 1761191693786, 'version': '2.0.3', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/udi-climacell-poly.zip', 'home': '/var/polyglot/pg3/ns/0021b9026dfb_4', 'log': 'logs/debug.log', 'logLevel': 'ERROR', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'climacell.py', 'shortPoll': 1800, 'longPoll': 86400, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '1de8f24e-3779-485c-b398-8d17b4117394', 'noLicense': 0, 'latestVersion': '2.0.3', 'dbVersion': 1, 'developerMode': 0, 'allowIsyAccess': 0, 'requestId': 0, 'edition': 'Standard'} from Polyglot2025-10-22 21:00:30.479 Thread-2 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]}2025-10-22 21:00:30.492 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom2025-10-22 21:00:30.493 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom2025-10-22 21:00:30.493 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot2025-10-22 21:00:30.493 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot2025-10-22 21:00:30.493 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}2025-10-22 21:00:30.532 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices2025-10-22 21:00:31.371 MQTT udi_interface.interface INFO interface:_message: Profile installation finished2025-10-22 21:00:34.456 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2025-10-22 21:00:34.457 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2025-10-22 21:00:34.457 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2025-10-22 21:00:35.296 Thread-1 udi_interface INFO roomba-poly:addNodes: Discovery fround 3 robots!2025-10-22 21:00:35.296 Thread-1 udi_interface.custom DEBUG custom:__setitem__: CUSTOM: setup = Initializing connection to Living Roomba ...saving2025-10-22 21:00:35.296 Thread-1 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.2025-10-22 21:00:35.296 Thread-1 udi_interface INFO roomba-poly:addNodes: Create a new node for Living Roomba ...2025-10-22 21:00:35.307 Thread-2 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {'setup': 'Initializing connection to Living Roomba'}}]}2025-10-22 21:00:35.326 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom2025-10-22 21:00:35.326 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom2025-10-22 21:00:35.326 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{"setup":"Initializing connection to Living Roomba"}'} from Polyglot2025-10-22 21:00:35.326 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot2025-10-22 21:00:35.326 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {'setup': 'Initializing connection to Living Roomba'}2025-10-22 21:00:35.326 Command udi_interface.custom DEBUG custom:load: CUSTOM: -- checking setup / Initializing connection to Living Roomba2025-10-22 21:00:35.368 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices2025-10-22 21:00:39.463 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2025-10-22 21:00:39.463 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2025-10-22 21:00:39.463 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2025-10-22 21:00:44.472 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2025-10-22 21:00:44.472 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2025-10-22 21:00:44.472 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2025-10-22 21:00:49.478 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2025-10-22 21:00:49.479 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll Edited October 23Oct 23 by Lore
October 24Oct 24 Author Updated to 2.0.13 and when I try to discover my vac I'm getting2025-10-23 20:37:50.484 Thread-8 (userDiscover) udi_interface ERROR roomba-poly:getPassword: name 'roomba_port' is not defined Traceback (most recent call last): File "/var/polyglot/pg3/ns/0021b9026aaf_5/roomba-poly.py", line 779, in getPassword LOGGER.info(f'Connecting to {robot["ip"]} on port {roomba_port}') ^^^^^^^^^^^ NameError: name 'roomba_port' is not defined
October 24Oct 24 Fixed the name error in 2.0.14@Lore I don't see any errors in the log but I also don't see that it ever called the initialization function so I don't really understand what's happening.
October 24Oct 24 I updated to 2.0.14. Still seems to hang at initializing the first Roomba. I saw double messages so I rebooted and they went away. There might an issue killing the old version and updating. I also noticed a "module not found" DEBUG message during startup...2025-10-24 11:38:46.652 MainThread udi_interface INFO init:<module>: UDI Python Interface for Polyglot version 3 3.3.18 Starting...2025-10-24 11:38:46.658 MainThread udi_interface DEBUG udi_interface:write: CV or numpy module not found, falling back to PIL2025-10-24 11:38:46.658 MainThread udi_interface DEBUG udi_interface:write: PIL module not found, maps are disabled2025-10-24 11:38:46.659 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.3.22 [ISY: 6.0.0, Slot: 3]
October 24Oct 24 The missing modules are used for creating the Roomba room mapping, which the plugin doesn't use. Thus the missing modules are expected and not an issue.I don't know why it gets stuck trying to initialize, I don't have that problem with my Roomba, so not something I can easily debug. I did add some additional debug info a couple of versions back, but so far, none of the logs you've posted have had that specific debug log message.Please set the plug-in log level to debug, restart the plug-in, note the time and once it gets stuck, download the plug-in log file and PM it to me. That way I have the entire log.
October 24Oct 24 Lore, Bpwwer My system is acting the same as Lores. Finds rombas but fails to create the nodes. These rombas did work with the plugin a few year ago. Have been following along, debug log stream looks the same.
Wednesday at 04:32 PM5 days I am sorry I had to step away for a bit but am back in the country now. I uploaded your latest v2.0.14 and now it is connecting to my eisy but it is not creating the nodes for them after discovering them. I notice Lore already uploaded log files. If you need another set I can upload my logs as well but if you do not need it I don't want to overload you.
Wednesday at 07:07 PM5 days Success, Finally got my two roombas to install the nodes.Could not get the roombas to install the nodes by first installing the roomba node server and second setting roombas as instructing to connection mode. Program never setup the nodes. As others have experienced. Tried this :-deleted roomba node server in PG3 and eisy selected to install roomba node server on pg3 and set slot number ( did not start install)set both roombas into connection mode ( hold left botton until blue light circle on roombas)went and started install of the roomba node serveronce in installed it found both roombas in a few seconds and setup both nodes in eisythis has to be a problem with timing in the program ? deleted and tried again with only one roomba 1 in linking mode when I started the install for the roomba node server it found first roomba 1 that was in linking mode and installed the nodesfor the second roomba node server said to put roomba 2 in linking mode, found roomba2 but then never created the nodes. deleted againput both roombas in linking mode and then installed roomba node server, both nodes installed.hope this helps to debug what is going on with the program and as a way to get your roomba nodes installed Eric
Wednesday at 09:35 PM5 days @EricBarish Thanks for the details. It does give me a better idea of where to look for the issue.On 10/24/2025 at 12:49 PM, Lore said:Roomba_10-24-2025_124503_PM.zipThis file is not available (so the forum says). So I still don't have a full debug log showing the issue.
Thursday at 02:39 PM4 days Is it an issue with multiple Roombas?17 hours ago, bpwwer said:@EricBarish Thanks for the details. It does give me a better idea of where to look for the issue.This file is not available (so the forum says). So I still don't have a full debug log showing the issue.I PM'd you the file as well (at the same time I posted it.)
Friday at 04:33 PM3 days @Lore I don't have any PM's from you so I'm guessing it didn't go through. Maybe I don't have space for a large log file anymore. I'll clean up my PM's just in case.
Friday at 11:18 PM3 days @Lore Thanks. I don't see the log message that I added to help debug this so something strange is going on. I made some change that may help, but I'm not sure.Try the new version and then capture the log again.
Friday at 11:24 PM3 days I updated, but I didn't see the version change. Still 2.0.14. Here's the new log. Roomba_10-31-2025_42213_PM.zip
Saturday at 12:13 AM2 days Thanks. It did show a couple of the messages I added, but still doesn't seem to want to initialize the Roomba.Version 2.0.16 makes a slight change and I'm curios what happens.My working theory is that when it sends the notice, it interrupts the initialization so that it never finishes. If that's the case, I'm not at all sure how to fix it.
Saturday at 03:24 PM2 days I do see one problem in the log now. Looks like you only have 10 seconds to press the button on the Roomba before the plug-in gives up looking for the password. This one section of the code that had major changes to work with the latest Roomba library code.
Saturday at 06:38 PM2 days 3 hours ago, bpwwer said:I do see one problem in the log now. Looks like you only have 10 seconds to press the button on the Roomba before the plug-in gives up looking for the password.This one section of the code that had major changes to work with the latest Roomba library code.So it sounds like a need to move all my Roombas (and their chargers) to a line in front of my computer so I can push their buttons and discover at the same time?
Saturday at 07:58 PM2 days Just press the button's before you install the roomba app. They will stay in linking mode for a while after you press the buttons, then install the plugin and it will see the roombas in linking mode as sone as it starts and finishthe installtion , do not need to worry about the 10 sec. .
Sunday at 02:17 AM1 day Author Thanks deleted, put the roomba into linking mode, installed the connector, heard the roomba say "thanks your ready to clean" and I even see this in the log even on restart2025-11-01 22:15:32.487 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2025-11-01 22:15:34.402 Thread-1 udi_interface INFO roomba-poly:addNodes: Create a new node for Main Floor Vac ... 2025-11-01 22:15:34.402 Thread-1 udi_interface INFO roomba-poly:addNodes: Robot name = Main Floor VacBut yet no node is actually created in PG3 it's still blank, and nothing in the java admin console.
Sunday at 12:30 PM1 day This worked mutiple times for me. I did delete the plug-in from eisy also, not sure if this will make a difference. I'm still on 2.0.14 version. Did not update to 2.0.16. My roombas are a I3 and I7.
Sunday at 03:58 PM1 day Ok, I found what I missed when updating to the new getPassword code. It should now wait for you to press the button on the Roomba. Version 2.0.17 with this fix has been submitted to the store.
