hart2hart Posted Friday at 06:31 PM Posted Friday at 06:31 PM Would it be reasonable to select a variable on the offDelay device screen as offDelay time instead of only doing that through a program? Quote
Guy Lavoie Posted Friday at 06:40 PM Posted Friday at 06:40 PM (edited) 31 minutes ago, hart2hart said: Would it be reasonable to select a variable on the offDelay device screen as offDelay time instead of only doing that through a program? I don't think that's possible. The plugin would have to obtain the value of a variable through PG3 dynamically. Also...what sets the variable? Usually that would be a program. Just have the program also set the offDelay time for the virtual switch. Edited Friday at 07:03 PM by Guy Lavoie Quote
sjenkins Posted Friday at 09:00 PM Author Posted Friday at 09:00 PM 2 hours ago, hart2hart said: Would it be reasonable to select a variable on the offDelay device screen as offDelay time instead of only doing that through a program? @hart2hart, I get that setting the variable by program is a PITA if you are not changing it from your initial setting. I'm putting up a new beta v1.3.24 "as we speak" which addresses it, you get the credit as your previous comment triggered me on this one. Basically, why wouldn't we optionally allow the user in the JSON or YAML configuration versions to override the initial defaults? appreciate the dialogue, it makes this thing better as we go. Quote
